Need to replace drum bearings on maytag mah4000aww washer
  • 460 Answers
I will be very happy to assist you in this issue.
please follow this web side
http://appliancejunk.com/forums/index.php?topic=5233.msg21522#msg21522
Was this helpful?
i hope this answer your question
your rating and comment its very important to me
thank you
Posted on Nov 14, 2009
Model mah4000aww
Sounds like the main bearing on the back of the drum assembly has gone and needs replacing, the drum has moved out of alignment or the electric motor has burnt out. Best to have a Maytag repair tech or someone who is qualified to look at it.
Nov 05, 2012 | Maytag Washing Machines
MY NEPTUNE WASHER IS MAKING NOISE DURING SPIN CYCLE WHAT PART DO NEED TO REPLACE? MODEL # MAH4000AWW
If the noise starts before the drum starts to turn it might be the pump is obstructed. If it starts soon as the drum starts to turn then might be the drum bearing. If it is a knocking vibrating sound open the door and grasp inner drum try moving up and down and side to side . If there is any movement aside from the whole mechanism then the spider that holds the shaft to the drum is broken . Need a tech
Nov 23, 2010 | Maytag Washing Machines
The bearings in the Maytag Neptune MAH4000AWW washer are wearing badly. Sounds like a jet in my house when it spins. Can the bearings be replaced without replacing the outer tub?
If you think that there is no shake or play in the bearings a good wash with kerosene or diesel will take away all the dirt that causes the noise. The use light grease/heavy oil (90) to fill into the bearings.
Tip: repeat the washing with the diesel, use a good small brush and hold a tray under to pour the diesel and collect on to the tray till the noise subsides.
However if the bearings are still noisy then I think you need not replace the drum .
If Helpful credit me for the tip.
Aug 20, 2010 | Maytag Washing Machines
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAH4000AWW Bearing Noise When Spinning
12002022 is a seal kit only. The outer tub replacement is the correct fix, The part number for your unit is 22002907 and crosses over to 22004465. BTW. the replacement tub includes the seal kit and for the price I usually change the spinner assy at the same time..There are two part numbers for that.. It depends on your washer series which is determined by the first 2 numbers of your serial number... Hope this helps... Bill
Apr 18, 2009 | Maytag MAH6700AWW Neptune Front-Load...
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag neptune washer
Drum capaicty is 3.34 for the Neptune Model # MAH4000AWW
Dec 27, 2008 | Maytag Neptune Washer
Machine stops on it own
Take the board out and flip it over and check the r11 resistor. It is usually burned out.
Nov 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
904 people viewed this question
Top Washing Machines Experts
