Question about Refrigerators
I have a 1 1/2 year old fridge, I'm getting a
I have a 1 1/2 year old fridge, I,m getting a little water on my top shelf. The freezer section is above. Any ideas why?
  • Bill Schilz
    Bill Schilz May 11, 2010
    Have you by any chance put anything warm or hot on that shelf or one below?
  • Refrigerators Master
  • 1,606 Answers
Without a brand and model number , I can only give you the the overall process for drain cleaning .
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line .
Posted on Nov 15, 2009
  • 161 Answers
Check your defrost drain tube inside the freezer compartment. possibly clogged with ice or other debris
Posted on Nov 14, 2009
    Genius:
  • 1,075 Answers
Yes the drain plug hole is blocked.get two pipe cleaners and screw them togather and plunge them down the drain hole to unblock..adrian;;;
My refrigerator is set to #1 and I am having problems with items freezing in the refrigerator section, most notably the vegie bins as well as the top shelf. We have a stainless trio that is about five...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
I have an Caloric GFS207- 1L 01. before the winter came i had to turn down the freezer one number because it was to cold. now my problem is in my fresh food top self next to the box thing(damper maybe?)...
Yes - there is a cold air damper.
This regulates the cool air flow from the freezer to keep the fridge cool.
If there is condensation - i would suggest checking the door seal for warpage, tears or other abnormalities allowing hunid room air into the fridge.
Thanks
Feb 16, 2010 | Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice & water dripping in refrigerator
you have a clogged evap. drain and if you want the probelm to go away you need to that the back panel off of the freezer, then use a hair dryer to melt all the visible ice then use boiling hot water to flush the evap. drain tube which is also clogged with ice . once water flows all the way throuh the pipes as if you have flush the tiolet you have then cleared your issue
Jun 01, 2008 | Refrigerators
Refrigerators Logo
229 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
