Question about Orion1934 19" TV
I have an orion combination TV, VHS & DVD player. I cannot access the back of the set to see the model #. I want to know how to change the video input button. Don't see one.
  • 145 Answers
The button is on your tv factory remote control. a universal remote wont work. now you can try to physically go to the channel down button on the tv. keep pushing it until it counts down the channels, then it should go to video 1, video 2, line video, front video. fixed! enjoY!
Posted on Nov 14, 2009
How do I connect an external DVD/VHS player to an old Coby Cx-Tv1 television with no RCA cable?
It should have also an Audio in jack . Take a photo of it and go to some radio/tv parts shop for a converter. They know
May 17, 2015 | Coby CX-TV1 5 in. Portable Television
I am trying to reprogram the channels available on an Orion TV VCR/VHS combo without a remote and no menu button on this device's face for access
Hello
It is impossible to make an auto tune function to this TV without its remote control, as there is no Menu button on its front panel. OK.
Nov 24, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Hi i got a vhs/ dvd recorder from a friend who upgraded,but dont have a manual,i have set it up to my portable tv upstairs,which has a set top box,but dont really know if i have the cables right. the...
Hello Audrey,
If you can watch the videos on the TV, your cables are correct, but you don't generally record a video to DVD using the record button. Most VCR/DVD combinations have a DUBBING button on the front of the player and/or the remote control for copying from one to the other.
Additionally, some players can only record from video to DVD, some can only record from DVD to video and others will do both. On players that can do both, you need to instruct the player whether you want to record from video to DVD or vice-versa.
If you can le me know the model number of the player, I can let you know which recording options are available on your player, how to record and (hopefully) supply a new manual which you can download and print. The model number may be on the front of the player, but usually these are found on a label on the back of the player.
Regards,
BElectric.
Apr 14, 2011 | Televison & Video
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Hook up DVD
I hooked up my DVD player to the Yellow/Red/White inputs on the back of the set. I think you can buy a manual for $2.60 from the Orion website. Good luck.
Jan 05, 2009 | Orion STV2763 27" TV
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
VHS
maybe it is a default, ocnsult the manufacturer
Mar 29, 2008 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Orion combi 14"tv vcr vhs model cw1403(D)
hold the down volume button for 10 seconds.
Mar 25, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
User manual needed
Manufacturer's Phone Number may be 800-289-0980. Not sure if this is the manufacturer number, but it is the number listed on the Orion TVDVD092 box to call if you still have questions after reading the manual. I need a manual as well. I do hope that they will send me one.
Jan 02, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
Orion1934 19" TV Logo
143 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
