Question about Dyna-Glo RMC-8001SS Heater
Will not stay lit.
My heater will light, but after 5-10 minutes it starts sputtering and then goes out.
  • dajomar Dec 05, 2008
    My RMI 80NGT is doing the same thing but goes out in less than 2-3 mins.. I clicks off giving reason that the thermo coupling or thermostat might be bad.. We've blown out the jets best we could... Also noticed that the pilot flame when heateris lit is pulled away from sensor.. Could this have anyting to do with it?
I had the same problem with my RMC-8001SS heater, After about 7-8 minutes the pilot flame would start to sputter and go out. Try this test; Use a flashlight to look through the lower front grate, on the right side. There is a thin silver metal strip on the side of the brass pilot flame orifice. It is fastened with a screw on the top and is free on the bottom where it covers a hole in the brass tube. Get a long enough thin screw driver that you can put through the grate and touch the silver metal strip. Now, remove the screw driver and light the heater. Wait until the pilot flame starts to sputter, then using the thin screw driver, put a little pressure on the lower end of the silver metal strip. The pilot flame should instantly normalize. If it does, then this is your fix....
Remove 4 screws in bottom of unit and remove the center metal plate. The metal back of the heater can now be pulled out and up. There are two metal tabs at the top under the handle. Work the back piece a bit and the tabs will come apart, allowing you access to the inside of the heater. Hold the end of the brass pilot flame tube with a 7/16" wrench and remove the gas line with a 1/2". Take out the 2 screws under the plate that holds the pilot tube and thermo-couple. Now you can get at the silver metal strip on the pilot orifice. Remove the small screw holding the silver strip. Next, gently bend the strip to put a little downward bow into it. When you put it back on and tighten the screw, this will apply more pressure to cover the hole in the brass tube. Re-assemble the unit and it should work fine. I'm happy to have my heater working again!
Paul
Posted on Jan 16, 2009
    Scholar:
  • 41 Answers
Sounds like you have a blockage to the main jet. If you have a compressor just blow the jet out from the top and with a bit of luck it will clear it. If not you may need to remove the outer covering and find the pipe to the main jet and again using compressed air just blow it out. Usually not much goes wrong with these apart from blockages every now and then and most of the servicing places just blow them out with compressed air. Just make sure if you remove a pipe you tighten the pipe up properly when re-fitting it. Hope this helps
Regards
bryan
Posted on Jan 12, 2008
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
When I press down and turn the know the pilot lights but as soon as you let up on the knob to turn it there is a click and the pilot light goes out.. This is on my Mr. Heater Big Buddy
When the pilot lights continue holding the button down for a full minute and then release. It should stay lit then to allow you to turn it to the on position. If the pilot will not stay lit after holding it for the full minute, then the thermocouple will need to be replaced.
Hope this helps.
Sep 16, 2011 | Mr. Heater Big Buddy Heater
Pilot will stay lit but burner goes out about 1 minute after it lights
Sound like the flame sensor you could scratch around on it and try again.Possibe venting issue
May 14, 2010 | Water Heaters
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
The heater will not stay lit.
i have to start my heater manually. whats bi start it the controller works its when the heater hits its tempature it will turn off thats good, but when i re-start it with the control it wont start. i have to do it manually remove the cover on the heater and push a buttom on top. the pilot is always on?
Jan 31, 2009 | Williams 1403622 Gas Compact Heater
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Dyna-Glo RMC-8001SS Heater Logo
274 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
