Question about Microsoft Xbox 360 Console
Played a new game on my xbox 360, turned it off, & when I turned it back on a red blinking light was on the power ring. Tried unplugging all accessories/hard drive, but still same result. Any suggestion to work around the problem
  • Cyntage May 11, 2010
    Can you clarify in which sections the red light is blinking at? Top left, bottom left, top right, and bottom right or a combination of them
    Genius:
  • 1,093 Answers
Yes nealry all the red light problems happen because of overheating on the main chips, to fix it you will need to stop the heat build up.
To do this you can use a good Xbox 360 Repair guide
Posted on Nov 19, 2009
    Guru:
  • 212 Answers
If you get Red Ring of Death you need to first check how may red rings are you getting and do you see any error message on screen with red ring or the console does not start at all
When there is a general hardware failure. While this can be caused by any part(or lack thereof) on the 360, the general cause is from excessive heat, which stresses the solder joints on the CPU and GPU
What Do The Red Light Errors Mean?
* 1 light means you have had general hardware failure. If you to send it in to get it repaired, without a warranty would cost. Not to mention it can take up to a month for you to get your system back.
* 2 lights mean your console is over heating---TURN IT OFF NOW TO AVOID SERIOUSLY DAMAGING YOUR SYSTEM!
* 3 lights also mean general hardware failure.
* 4 lights simply mean there is a problem with the AV cable. Check the connection and replace if necessary.
basically when you get a RRoD you can try cleaning the connection point of your AV cable but if it does not work please send it to MS Support for repairs, i had 3 Red light problem and with error message E74 i send it Microsoft Support as my console was under warranty
I have 3 red lights blinking when I turn on the console. The light on the power supply box is orange. I have tried unplugging all connections and plugging them back in, and I have also tried different...
It appears there is an issue with the power supply, which resulted in shorting out the console. Depending on the age of your 360, you can contact Microsoft Support with this issue and they can provide a solution. If your console is under a certain age, they can replace the console for you at no cost. If it is an older model, you will be better off just buying a new console and transferring your data onto the new 360
May 04, 2011 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
One light flashes red on xbox 360
Got answer from WikiAnswers give credit!
Meaning of Red Light on xbox 360 Is this the Ring of Death?
No, either you have one of your cords unplugged, such as the RCAjacks, or some other hardware issue that probably isn't as serious as one you would have with the 3 light ring of death.
How to fix it.
Since it's just one light in the red ring, you may be in luck. Most times, this error can be resolved by powering off your xbox, unplugging it from the back, then unplugging the power brick. Plug them all back in and power the box back up. If this doesn't take care of the problem, microsoft also suggests taking the harddrive out and putting it back in.
If all else fails.
It may be time to contact Microsoft support. Hopefully you can save you info. Goodluck.
May 01, 2010 | Microsoft Xbox 360 Console
MY Power Supply light is blinking orange and xbox 360 want turn on
I hate it when people put "Red ring of Death" for a ORANGE flashing light on the power bar and actually a red ring on the front of the Xbox (which then would mean the red ring of death)!
I just fixed this problem for a friend. They had a contoller charging lead plugged in to the front which had a bad connection in it. Thats all it was so I just unplugged the charging lead and it worked.
So Unplug everything except the power and see if it works 1st, if it does then plug things back in one by one and see when it starts to flash and thats your problem lead there.
Aug 04, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 lost all power
probably over heating of power supply.
take a air gun and blow out the little vent holes at each end, also listen to hear if the fan comes on, inside the power supply.
Feb 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
Dec 26, 2008 | Microsoft Xbox 360 Console
360 Power chord light red
Unplug it and get a new one microsoft wont fix that!
Jun 30, 2008 | Microsoft Xbox 360 Console
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Red ring
how many red lights do you have in the ring?
Jun 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
