Question about Whirlpool GR448LXPQ Electric Kitchen Range
When I try to use the self-cleaning feature on my oven, this message appears after approximately 2 minutes: E1 -F5- what's wrong?
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$&U*%I*RY
Posted on Oct 01, 2010
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
E1 -F5- Error code appears when attempting to start self-cleaning mode.
F5
lock
1.
If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes
Dec 04, 2010 | Whirlpool RBS275PD Electric Single Oven
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Self cleaning feature
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.FGRT%$^
Jan 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self Cleaning won't work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%TY
Feb 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
E1 F5 error message when try to activate the self clean
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore oven locked after celf cleaning
Aug 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Whirlpool GR448LXPQ Electric Kitchen Range Logo
79 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
