Question about Car Audio & Video
I have a Pioneer DEH-P5000UB with USB port. I want to know if I can connect an External USB 2.5 Hard Disk in the USB Port.
  • Car Audio & ... Master
  • 32,281 Answers
Yes you can.
If the USB port says that your device has exceeded the power the USB port can deliver then you need to connect the USB hard drive to a powered USB hub and connect this hub to the computer's USB port or connect a power adapter (5 volts) to the external USB hard drive adapter case.
Posted on Nov 14, 2009
I cant find the usb port
its actually at the back of the unit its a cable thats wired in probably about 15 cm long its on the top left hand side, who ever wired it in may have led the lead underneath so look around there, theyve hidden it at the back to clean the unit up and hide the wires from exposure.
Jun 22, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
How to reset my DEH-P5000UB, because my display turned off, weird
Re:"everyother light turns on the faceplate but the display is off"
That means that the unit is either faulty, or one of the two powered lines required had not been connected.
The unit is reset by simply disconnecting the connector at the back.
This will not help in fixing the problem.
Ensure that unit is wired properly. Use a voltmeter to test wiring.
Here installation manual with proper wiring.
Here also the owner manual.
May 26, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My hard drive doesn't show up
If the external hard drive is not detected by yur computer, try first connecting the drive on a different USB port so we can test the USB port and then after that if still not yet detected try a different USB cable to test the cable and after that still not detected connect the drive on different computer so we can see if this is already a hardware problem.....
Jan 05, 2010 | Sabrent eSATA External Drive Case
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Iomega 500 MB External Hard Drive does not spin when you turn it on. Light just flashes white and blinks
The hard disk most likey is faulty. Remove the hard disk from the enclosure and connect it to an USB hard drive adapter and the plug it into a working computer's USB port.
If this computer cannot detect this as an external hard disk then it the hard disk is faulty and needs to be replaced.
If the hard disk is OK the the Iomega case is faulty and it needs to be replaced.
Sep 21, 2009 | Iomega Computers & Internet
Help with ipod connection to cd player
You must use 1 of 3 methods to connect your iPod
1. FM modulator to wirelessly broadcast on a low FM band
2. iPod 3.5mm male/male direct connect cable.
3. iPod USB connection - with Pioneer iPod adapter module.
The direct connect 3.5mm port is on the back of the unit. One plugs into the radio - one plugs into the iPod headphone port.
Click HERE for your owners manual in PDF format.
CLICK HERE for the installation manual
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
