Question about Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05
How to Get Hot tub off sleep mode
I have a St. Lucia Hot Tub with no manual and need to know how to get it off sleep mode
Balboa system
hot tub model #:1108IN-NP-P-GR-MP-62
  • 37 Answers
Press temp button and then the light button in sequence.
Posted on Dec 10, 2009
I have a great lakes 2006 hot tub. how do i get it out of sleep mode and make it hold constent temp
Posted on Nov 29, 2009
If hot tub is in sl mode. How do I change it so temperature goes up
Hi, this sounds like a Balboa pack and topside control. press the temperature button along with the light button. This should put you into the filtration mode selection. Then toggle using the temperature control buttons until you find your mode ST for standard and EC for Economy or SL for sleep. You can find more information here. How to change the Filter Mode on Dream Maker Spa
Jun 05, 2015 | Pool & Spa
Balboa hot tub wiring diagram
CAUTION: Electrical work and repairs can be dangerous, especially around water. There is a risk of shock or electrocution, which could result in serious injury or death. We strongly advise that hot tub electrical wiring be referred to a licensed electrician. Local code requirements for wiring vary and may differ from the educational examples on this web site. The local code regulations must be followed, with permits and inspections obtained. The installer should read and follow the hot tub owner's manual and associated electrical component owner's manuals and instructions.
Try this link: file:///C:/Documents%20and%20Settings/Gil/My%20Documents/Troubleshooting%20&%20Service%20Manual%20230V.pdf
Jan 21, 2014 | Delta Tools & Hardware - Others
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a density riverspas hot tub and it is stuck in sleep mode and there for won't heat up how do I take my density riverspas hot tub out of sleep mode
Difficult to answer without knowing the "Brand" of your Spa Support Pak System. Lets presume you have the most common basic pak available - Balboa.
Press "Temp" button and then immediately press "Light". You will then sequence between 3 modes:
  • Economy - may display as Ec
  • Standard - may display as Std or St
  • Sleep - may display as Sl
Should save last setting
Dec 03, 2012 | Pool & Spa
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05 Logo
6,574 people viewed this question
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
