Question about Sony PlayStation Portable (PSP) Console
It will turn on while plugged in the charger but not without
    Guru:
  • 352 Answers
Sounds like the battery is dead. try a new battery as these rechargeable batteries will go bad and not charge anymore.
Posted on Nov 16, 2009
My tonbux 10.1 will not switch on
Most likely the charger is not functioning. Test it with a meter where it goes into USB port and plugged into wall outlet.
Dec 01, 2014 | Tablets & eReaders
Ac keeps shutting
Remove the battery and plug in the AC adapter. If you can not power on the laptop, your AC adapter has gone bad on you and will need to be replaced.
If it will turn on with the AC adapter, place the battery while the laptop is on. See if it registers the battery as charging in the task bar. If not, there may be something wrong with the battery or the components connecting to the battery within the laptop.
Also you can below steps to check:
1) take the battery out of your laptop and the laptop charger
2) plug your laptop charger in your laptop without the battery in it,
3) Try to turn it on the normal way:
If it turns on, then your battery has gone, (Its drained and run out of use like all batteries do)
if it stays off then its a charger problem
You would want to hope its a charger problem as they are cheap and easily replaceable
Hope i helped
I guess its a charger problem because its not turning on and the laptop automatically would use the charger as a main power supply if the battery doesn't work
and oh by the way
If the battery isn't in it, your laptop will act as a pc whereas if you plug the charger in it will work, but if you take it out while the laptop is on then it will go off instantly without a successful shutdown which could mean a loss of work
Regards,
Rahul
Jul 14, 2013 | Compaq Presario CQ62-112TU
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Nov 12, 2010 | ASUS A9RP Notebook
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Laptop won't turn on
It may very well be a bad jack but it also could be a bad battery that is not retaining charge. Yes, a bad battery will cause many laptops not to turn on.
1- how does the charger jack fit; is it loose or wiggle when pluged in? or does it fit snugly with no movement when plugged in? If the charger no longer fits snuggly or moves a lot when plugged in, it may very well be a bad dc jack. Not a task for a DIYer but well worth having fixed.
2- Try removing the battery and see it powers on the charger only. Some laptops will not work without a battery and some will. If this is a Gateway, it probably will work without a battery.
Jan 08, 2009 | Gateway MX6448 Notebook
02 xda orbit..
If the light doesnt turn to orange after a few minutes on the charger then the problem hardware related. Try another battery if there is no change then there is fault in the device, and repairs are required.
also you can try
this:
1. Plug it in the Charger without the battery inside.
2. switch on the power.
3. Without removing the charger plug in the battery.
4. Light should turn orange.
5. Wait a moment or two then power it on.
that might get it to work.
May 09, 2008 | O2 Xda IIs Pocket PC
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
