Question about Brother GX-6750 Typewriter
Characters ok then after a month all characters are different to the disgnated keys (e.g: A is M etc...) is it a defective motor or ic?
    Scholar:
  • 49 Answers
The hammer may be coming to rest into or otherwise be interfering with the movement of the printwheel, It could be a bad motor or the hammer cam may be not cycling properly to its' home position or may require replacement of the hammer cams assembly. Typically, if you observe the hammer moving slightly towards the paper after a print cycle, then the usual repair is replacing the cams assembly. If you are technically inclined, it is possible to remove the cams assmebly and retime the hammer cam by repositioning the helical spring into a different slot in the flange on that cam assembly. This will establish the proper position of the hammer cam at rest position.
Posted on Nov 16, 2009
How do I turn off the blue keys on my acer keyboard? I do not have a fn key
Solution 1 - Permanent OFF (windows 7)
Go to Start menu > Devices and Printers
Right click on HP Wireless Keyboard and Mouse Kit (yours may have slightly different name)
Left click on Region and Language
Left click on Change Keyboards button
Under General tab go to > Default Input Language section > select English (Canada)-US
Under General tab, now go to > Installed Services section > Keyboard heading > click on item for Canadian French then click the Remove button on the right,
Repeat step 6 to remove line item Canadian Multilingual Standard
Click Apply button at the bottom of window, then click OK button to get out of the window, click OK to get out of final window
Close your Devices and Printers window and you are done FOREVER with the unwanted characters! :smileyhappy:
Solution 2 - Temporary toggle between special/normal characters
If it's like mine, the default keyboard setting requires you to do the following:
press hold left ctrl+shift, then tap right shift key, this should toggle between the special characters and back to the normal characters when steps are repeated.
Mar 17, 2015 | Acer Computers & Internet
DVD PLAYER NOT INITIALIZING
ok sir! at your case! you have defective power oscillation! or  your two regulator IC is defective thats why your unit is not oscillating on!
Oct 20, 2007 | Toshiba HD-XA1 DVD Player
Nokia 2700 model not swiching on
brother the power ic of your phone is defect on your problem or if you can just read at this site if you want to but for me its the same problem of what my friend just hade last month...... http://www.mobilefile.info/2700c-power-button-not-working-solution/
Mar 25, 2011 | Nokia Classic 2700 Cell Phone
Some of the keys are showing different characters than are writte
open phone remove dots clean it with ip and see4 if its working if not replace keypad ic
May 24, 2010 | Logitech Wireless Access Duo Optical...
Trying to get the asterisk @ for email on a computer
Probably your keyboard is set to a different character set or language. To fix this go to control panel and click keyboard properties, there should be a tab for input locals. This sets the language and character set for your keyboard. To use various characters, you can use start , then type charmap.exe in the box and it will bring up a character map where you can select various characters such as the copyright sign etc. to use. Most windows from 2000 newer also have osk.exe, this draws up an onscreen keyboard you can click with your mouse to type.
Aug 29, 2009 | HP Compaq Presario 2200 Notebook
Will not connect to my network
no you do not need ascii characters,well you might want to go into the port configuration for your printer,select tcp port,make sure it is checked(it should have a 192.168.etc address ) hit ok try a test print.
good luck
Aug 26, 2009 | Lexmark X4650 InkJet Printer
Getting different character printout after replacing Timing and s
hello sir; there are so many difference sub-manufacture around the world, they made their ovwn language, so you have to reset, just press the manu key search for language,pick up english should be ok!
Dec 30, 2008 | Dataproducts FP 2000A Matrix Printer
Characters are scrambled
check connections of R.G.B.and 15 pins to end thenif ok then check positive Vcc at the ic on crt base if less than 12v then check regulater ic if faulty replace it display also can be corrected by adjusting ring magnets on yoke coil
Oct 14, 2008 | LG Studioworks 45 14" CRT Monitor
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Brother GX-6750 Typewriter Logo
105 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
