Question about Nokia 6110 Navigator Cell Phone
I have moisture behind the front slidin screen of my navigator6110 screen not workin anyone know how i can fix it or should i bin it
  • 945 Answers
Try and dry it out , remove as much as you can of the mobile`s exterior ,and battery .Just put it in a warm room to dry out for about 6 hrs.Donot put it on the radiator.
If not you have tried your best.
Posted on Nov 14, 2009
Moisture on the door of my LG WM2016cw
washing machines do do this its all depends on the atmosphere, if it's excessive clean out the tray were you put the powder in as this is where the washer gets it air flow from, if it stays damp in there it will show on the door glass.
Jul 14, 2017 | LG WM2016C
AV-65WP84 when i connect video or the antenna the screen start to blink green does anyone knows about this problem on this jvc i-art tv?
Have someone open it from the front (front grill below screen is secured on either side at back with screws) and remove inspection plate behind grill--someone needs to locate the small black block with 6 adjustments and locate the green SCREEN not the green FOCUS and turn the green slightly down.
Care needs to be taken as set must be on--do not touch anything else inside as dangerous voltages are present when set is on.
Mar 16, 2012 | JVC Televison & Video
I took out the 3 screws that hold a round grey plastic platform in order to remove the bin that holds the whole beans and that you set the grind with. How do I put the bin back so I can adjust the grind?...
Hi bross123,
Doesn't seem like anyone wants to tackle this. I don't know much about these coffee makers, but thought I would at least find a customer service number for you. If you haven't got it figured out by now...
Here it is: Toll Free: (800) 459-5594
Hope that helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | Rancilio Rocky Doser Espresso Grinder...
Hello I have several (7) blue lines in an arch pattern spanning across the entire screen. Mostly noticeable in dark to black scenes. Was wondering if anyone knows what causes this and if there is a way I...
The Blue CRT ( Picture Tube ) has a short. You may be able to do a temp fix by turning down the Blue CRT drive level ( Located behind the front speaker grille )untill the lines disappear. But its only a temp fix. The Blue CRT will most likely need replacement.
Nov 04, 2010 | Sony KP-51WS500 51" Rear Projection...
Black screen on my pc cam notecam pro usb pc cam
i have a problem with my pc camera i have vista ultimate on my pc and it finds the software downloads it and says it is workin with no conflicts but when i go in messenger and try to activate my pc cam it shows the camera but with a black screen can anyone help me please
May 01, 2009 | D-Link Computers & Internet
My GE Monogram Ice Maker keeping turning its self off and the cleaning light starts flashing. We have cleaned the unit using the nickle safe product. Anyone else have this problem?
the rate the light flashes is a code for trouble shooting the electronics on the unit ( such as bad coil sensor, bad bin sensor or shorted grid cutter) if you will look behind the front grille you should find a tech sheet that will tell you what the flasing means and tell you what components to replace. BTW the most common failure is the cutter grid and bin sensor. the sensor is the white rod on the right hand wall inside the unit. besure it is plugged in. Let me know if I can help you futher. thanks Peyton
Mar 21, 2009 | GE Monogram ZDI15C Automatic Icemaker
Not Workin'
Dismantled the bastid then binned it. These things are NOT worth having.
Feb 12, 2009 | Philips Magnavox 52MF437S/37 52 in. LCD TV
LG KU990, touchscreen not responsible or not recognise
i have the same problem. i opened up my phone and saw a tiny chip thing right behind the screen fried. im thinking it happened because moisture got into the phone. moisture gets into your phone when you take a shower and leave your phone on the sink or something.
Jun 04, 2008 | LG KU990 Viewty
Blacn screen
Has the phone been around any moisture (shower, cook stove etc..?) It may have drawn moisture. Take the battery out and put it into a bag of dry rice. I know it sounds silly but thats the easiest fix.
If that doesn't solve the problem you may have to send it in for repair. If you can tell me the make and model i may be able to help more? Good Luck!
Oct 06, 2007 | Samsung SCH-u540 Cellular Phone
Nokia 6110 Navigator Cell Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
