A load was very off balance. It shut off a few times. She got it to finish the cycle but now it won't come on at all. Not even a hum for water filling. Is there a censor preventing it from starting now?
  • 68 Answers
Try unplugging the washer for awhile to let the board reset. You may have tripped a safety.
Posted on Nov 14, 2009
AMD 121 won't shut off, or change cycles. Continuously "hums".
Did you try just unplugging from the wall outlet, and let sit for 15 seconds and plugging back in. Sort of like a re-boot on the computer? Just a suggestion.
Jun 30, 2014 | Ariston Technologies AWD 121
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Whirlpool quiet wash plus DU920GWGD4 runs after cycle is finished. Just hums, no blades turning. No sign of leak... If I turn circuit off then back on it is fine until it runs a few times again. ...any...
Water air lock problem. Check your inlet for free flow.
Pour water from the front and mostly it will ease the problem. After this cycle it should work OK. The humming is due to water starvation in the motor.
Mar 30, 2010 | Dishwashers
Brand new. Load gets stuck on 14 minutes or some other time & repeats over & over. Wont finish cycle. We have to use the drain & spin to get the water out but then clothes are not rinsed well....
Sounds like you are probably doing a very bulky or real off balance load on a high spin speed setting. The washer is trying to get the load up to spin speed, but the load is too off balanced. Try the lowest spin speed setting for that load. If it makes it through that, then power machine back on and just push the spin speed button until the next higher speed shows up, and then the start button if you want to spin it out better. If it still didn't make it through the original cycle on the lowest spin speed, your load must be way too off balanced, like one coat that is saturated with water. If that is the case, you may even have to squeeze some water out of it by hand before you would be able to get the washer to get it up to spin speed.
Mar 21, 2010 | LG WM2487H Front Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Calypso Washer troubleshooting
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#@#$%
Jan 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
