Question about Verizon Communications HTC XV6800 Cell Phone - Blue
I accident reset my htc and when i tryed to use the internet explorer it says i need a username and a password to use it, but i have no idea what they are, can anyone please help me?
What is my wep key
A WEP key is a security code generated in your wireless router.
You need this code in order to connect to your security enabled, wireless network.
If you log into your router you should be able to find it in the wireless security settings.
It can be a word, phrase, or a bunch of random characters.
Mar 26, 2011 | Computers & Internet
Took unit out of storage. Cannot access 192.168.1.1. Have set proper IP address. Keeps asking for username and password, and admin doesn't work. Lost my created username and password. Please help
just try this. reset the hardware EOC-3220 then,
in your internet explorer browser type, 192.168.1.1 when you get in, it will ask username and password
put admin in username and leave the password blank. or put admin in username same in password.
hope it will help you.
Feb 04, 2011 | EnGenius EOC-3220 (EOC3220)
My router did not come with any software do i need it because i cannot get mine to work
Please reset the router by placing a pin in reset hole and push the pin sslightly, (remember you need to do this when the rrouter is in ON state)
Then connect your router to your computer using ethernet port (this is for configuration) and also connect the ADSL cable.
now open internet explorer and type in //192.168.1.1
Then it will prompt you for username and password
Username: admin
Passsword: password
this username and password is by default.
then configure your router as you need by changing display name, password authentication, MAC registration etc...
If you face problem with connecting internet even following the above steps, then you need to contact ISP(internet service provider) for settings.
Thanks,
Satheesh
Jan 04, 2011 | ASUS RTN10 wireless router
Trying to set up ethernet/wired router , linksys WRT54GS setup accepts correct username but not password ,ISP is a verizon DSL using a westall 6100 . DSL set to bridge , user name and PW are correct , have...
you can try resetting the linksys router once by pressing and holding the reset button using a toothpick for 30seconds when the power is turned on...then open the linksys router setup page by typing 192.168.1.1 in internet explorer...go ahead and change the connection type as "dynamic"(if you donot use any username,password for going online) or change the connection type as "pppoe" and enter the username and password over there in the fields provided...it ll fix your problem for sure....
Apr 03, 2010 | Computers & Internet
I am trying to set the internet connection on my wii system. At the access point - its' locked and it's asking for a password or key for my wireless router. I have no idea!!
acutlaly the default user and password for a NETGEAR wireless router is
USERNAME: Admin (no capitals)
PASSWORD: password (NO Capitals)
you might look on the bottom of the router and look for the default address: eg: 195.242.31.0 go into INTERNET EXPLORER and type that in the search bar then log in with the username and password i gave you and turn off a key for entry to the wireless router, or you can change the password- EMAIL ME AT JACKSON-H@HOTMAIL.COM if you need a picture guided conference.
Dec 26, 2008 | Computers & Internet
I have laptop with XP PRO and have AOL as my main source of internet in the UK. I am currently in Cyprus and the hotel has provided me with Username and password to access their internet.My wireless...
Sometimes other programs, such as Firefox and AOL, can accidentally be set to your default internet browser. This is how to change it back to Internet Explorer on Windows XP.
[edit] Steps
  1. Open Internet Explorer
  2. Go to Tools > Internet Options
  3. Click to the Programs tab
  4. Click Reset Web Settings
  5. When the pop-up menu comes up, select Yes.
  6. Another method that does reset all your other options:
  7. Open Control Panel and double-click Internet Options.
  8. Click the Programs tab.
  9. Click to select the Internet Explorer should check to see whether it is the default browser check box.
  10. Click OK.
  11. Start Internet Explorer and when you are prompted to make it the default browser, click Yes.
Nov 05, 2008 | Computers & Internet
Hi need to log in my rourter
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser.
By default the ip address should be set to 192.168.1.254
type .........http://192.168.1.254
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank.
Click the Ok button to log in to your router.
If you already had a password, you need that or need to reset the router to factory settings in order to start over again.
Oct 29, 2008 | Blitzz Technology (BWA611) Router
Can't Open Internet Explorer
You have to contact your service provider. That's a thing which is done by them to secure there internet service. They will give you the username and password. I evn tried that and they asked me to type the modem name and 'admin' as a password. For example, my modem is STstarcom. so the username wax starcom and password: admin.
Thank you.
Aug 09, 2008 | Zyxel Prestige 841 (91-004-226010) Modem
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Verizon Communications HTC XV6800 Cell Phone - Blue Logo
82 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
