Question about Pride Mobility Products Jazzy 1170 XL Plus
I need wheel for my jazzy 1420 where i can get them
  • 29 Answers
I'll get you one and drop ship it to you. email me. smithrm70@hotmail.com i'm in atlanta.
Posted on Nov 20, 2009
Jazzy 614 HD. Motor runs but the wheel does not turn
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Jan 31, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
Have a jazzy elite bought it for $ 200 new has been making a pronounced clicking noise while in operation
hi tighten the centre wheel nuts if they r loose they will make a clicking noise hope this helps
Dec 12, 2015 | Pride Mobility Jazzy Select Elite - Jazzy...
My active care 1420 spitfire scotter wont start an is blinking green
You need to consult the owners manual to determine what
the blinking light means. It will flash from 1 to 9 times and
repeat the cycle. Count the number of flashes and refer
to the manual to see what the problem is.
Jun 30, 2015 | ActiveCare Spitfire EX 4 Wheel Travel...
My pride jazzy electric powerchair will not unlock on one wheel, it only has one lever in back to release both wheels
Your jazzy chair should have 2 levers. There is a lever for each wheel. if the other wheel does not have the lever, then you are missing the lever that would release the wheel. Have a local tech look at it and they may be able to get the parts needed to release the other wheel.
May 09, 2015 | Pride Mobility Products Health & Beauty
Pride jazzy quantum 1420. working fine until today. when turned on, lights by joystick all flash on and off repeatedly. chair does not move. Any suggestions?
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
Mar 03, 2011 | Pride Mobility Products Quantum Jazzy 500...
My mother-in-law has a jazzy 113 for about 6-7 years and the 2 wheels broke in half. How can this happen when it is a solid wheel? Please let me know what to do. Its the back wheels.
Liz First Did Medicare buy MIL's chair? If they did contact me @ lennieg2000@yahoo.com and I'll give you more info. Now after that long the tires get brittle and usually need replacement. You can contact the provider where MIL got her chair and have them get the caster wheels for the chair. Hope this helps
Sep 29, 2010 | Pride Jazzy 1113 Power Chair
Jazzy 1420 not 1170
sounds like the wiring from the motor to the controler is not making good connection, try unpluging motor wiring from controller box. Use a plastic safe elec. contact cleaner and lube spray on connections. water in the joystick can also cause this.
Jan 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Battery wont take a charge
How long you using this battery? Tighten your cable battery terminal and charger connector.
Regards,
mas Didiet
Nov 02, 2008 | Pride Jazzy 1650 Heavy Duty Power...
Removeing Jazzy 1170 wheel
Yes, you need a puller:
1 Remove the Nylock nut and washer (3/4 socket)
2 Pull the wheel with a 2 tooth wheel puller
Oct 29, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Jazzy 1170 XL Plus Logo
48 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
