Question about KitchenAid KEBC206 Electric Double Oven
All 4 lights inside both ovens stopped working. they are the 5volt double pin 12 watts. they are not blown - all were working earlier today. I reset power from the breaker, heating elements and computer panel is working fine. simply all inside lights are not working. the oven light switch on the panel still makes the beep sound pushing the light display on and off. Is there a simple fix?
  • mbyrd1967 Nov 14, 2009
    Tell me how to check for power at the switch? Your comments said"if you can", how do I do that? do I have to pull the double oven out of the cabinet to access the panels?, then how do i access the power switch? Then how do you use the "Alligator clips?" and what do I attach them to. I am somewhat mechanical, but it sounds like I need to call a repairman in to test all this. I was hoping to avoid this.
    President:
  • 1,515 Answers
Hi, If you can, check for power at the switch. You can also bypass switch with a jumper wire with alligator clips at each end to see if the switch is bad or open.This will tell you that the switch is faulty.That will get them to work again.
Sincerely, Shastalaker7
Posted on Nov 14, 2009
  • Robert Horton
    Robert Horton Nov 23, 2009
    Hello, I am very sorry for not getting back to you a lot sooner, and you have probably taken care of the problem. I just wanted to say that I was thinking of a regular oven or double oven and I am not sure why I took that path. As you put it, is there a simple fix? I wouldn't say simple. You would have to pull the oven out far enough to get to the screws that hold the front computer touch pad out to find the micro switch that would control the lights. You say you are somewhat me-ch. inclined, so locating the switch and taking it down to have it checked would be rather easy for you. No insulated jumper wires with the clips on the ends to bypass it. Again, I apologize for the rather long delay and the 1st solution.
    Sincerely,
    Shastalaker7
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
I have a Whirlpool RBD275PDS14 double oven. It
Look for a blown fuse mounted on back of the controleb59c28.pngtis page is in the MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2010 | Whirlpool RBD305PD Electric Double Oven
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Display works but no lights on either oven and no fan
If the display is flashing, it sounds like the timer needs resetting
U need to refer to your instuctions on how to do this..
If it does it again once u have reset it, then I suspect that the oven element has blown..
Pls leave feedback.
Thanks.
Nov 28, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Jun 02, 2008 | Blodgett Ovens
My oven isn't warming up
can you verify the ignitor is working (ie: can you hear it sparking)?
1. If no, and you are absolutely sure there is not a buildup of propane inside the oven (or house for that matter), you can try lighting it with a match. If that works, you need to replace/reposition your ignitor.
2. If yes, do you smell propane after trying to light the oven?
A. If yes, STOP and get it fixed..
B. If no,
1. Check to see that your propane tank isn't empty?
2. Verify the regulator supplying the oven with propane is actually sending gas to the over (might need a repairman for this)
Dec 22, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
KitchenAid KEBC206 Electric Double Oven Logo
Top KitchenAid Ovens Experts
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
