Question about Kenmore 22.7 cu. ft. / 643 liter Chest Freezer 13351
The lights are working, but the compressor won't turn on.
  • 909 Answers
Get to the compressor and feel its temperature. If it is cold, then the thermostat will be faulty. Not impossible, but the clixon and run relay inside the electrical box could also be faulty. One needs a digital tester to check both.
Posted on Sep 24, 2013
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Magic Chef MCCF5WBX clicks but compressor won't come on
if it just hums or buzzez you will need to check the start capacitor on the compressor if it is stuffed you need to buy around 15uf---25uf cap @400volts depending on the size of the motor
Nov 19, 2012 | Magic Chef Chest Freezer MCCF5WBX
Freezer won't turn on
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Sep 12, 2012 | Kenmore Freezers
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
The starter is no longer available. I have found a generic starter here: http://www.appliancepartspros.com/part_details.aspx?part_id=4503017 Does this look like it will work? They have different...
I use this on a regular basis and have had no issues. I believe it will work. If I had some numbers from the compressor plus a brand name such as Copeland, Tecumsah, embraco, etc., I may be able to tell you more about the compressor HP.
Jul 17, 2017 | Haier 7 cu. ft. / 198 liter Chest Freezer...
My beverage air refrigator ri18 compressor turns on sounds like it works but doesnt get cold
1) Check the compressor working or not.. Air cooling type condenser fan may be not working properly.
2) Compressor working but not properly. Last side of condenser (Filter) Light Heat or not.
3) Inside Cooling area do not get cooling. may be gas leakage problem.
4) My opinion check Gas pressure Low and high side.
Mar 26, 2011 | Freezers
High Temp light will not go off even though the freezer seems to be working. Compressor does not stop running
What makes a compressor to run constant is the thermostat. Bang on it to see if it will turn off. turn the setting to 1. if it still wont shut off replace cold control (aka thermostat)
worry about the light later hope this was helpful
Mar 29, 2010 | GE 13.7 cu. ft. / 388 liter Upright...
Lights are on but compressor won't work. Less than 2 years old.No display on temp control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back onand listen for a click from the compressor relay as the compressor tries tostart.
Is the compressor motor running.If no check starter/overloadrelay.
If the relay is ok the problem is the compressor which normally has a five year warranty.
Oct 16, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 22.7 cu. ft. / 643 liter Chest Freezer 13351 Logo
73 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
