When I place the dvd in the tray of my Panasonic DVD-S35, the player is trying to read the disc. After a few seconds I get a ''no disc'' message and the player turns itself off. I also saw a HO2 error code. What is the problem? thanks
SOURCE: Conia M580 DVD player has
Easy... follow these instructions
Testimonial: "Many many thanks for your help - your instructions were dead-easy to follow and I've now successfully rescued my much-prized "Black Books" DVD disc!!!"
SOURCE: HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
SOURCE: DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
SOURCE: Panasonic DVD Player RV-31
spring motor bad need replaced
Manufacturer
Panasonic
Part Number
RXQ0745
Description
MOTOR
Sub
RXQ1218KIT
