Question about HP Pavilion dv6000z Notebook
Sometimes when I open the laptop to start using it it will not start and will have a black screen. I will have to turn it off with the power button and then back on. Sometimes I have to do it more than once. Only happens every couple of weeks.
  • Jack Jacobs Nov 17, 2009
    I do not think the problem is with the backlight. Normally I have the sound on mute. When having the problem above my mute light is on. If the computer starts up okay the mute light is off.
    Problem Solver:
  • 11 Answers
The backlight on the LCD may be going out. This model range of laptops were notorious for this issue. HP has an active extended warranty recall out for them so you better get it in to them so they can fix it for free while you can. If you don't want to send it in, you may consider getting an external monitor.
Posted on Nov 14, 2009
  • MR F. Nov 17, 2009
    Sorry. Forgot to add the link to the Warranty Enhancement. Here's where you need to go to determine if you need to send it in or not.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • MR F. Nov 19, 2009
    This has nothing to do with the keyboard back light. Read the Warranty enhancement and follow the instructions.
My hp pavilion elite m9152p shows a black screen. If i leave the computer for a few hours and come back the computer is still on, but the screen is black. monitor says no signal... I always have to hold...
Does the power button flash when there is a black screen? Could be that the laptop is in hibernation mode. Go to the tray icons next to the clock, click the battery symbol, more power options, and change the settings of "turn off display" and "put the computer to sleep" to "never". Usually to get the computer out of sleep mode, you just click the power button to turn it on again.
Hope this helps.
Aug 13, 2013 | Computers & Internet
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Laptop hpg60 black screen and power button remains on
Dear gorgaman1
Open your lap again and ensure that you connected all parts correctly especially the screen chip.
Best Regards
Mazagange
Apr 10, 2013 | HP G60-535DX 15.6in Laptop PDC 2.1G3GB...
Toshiba Satellite - black screen only when plugged in
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
Jul 07, 2010 | Toshiba Computers & Internet
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Black screen
try to change your smps ( power supply unit) with a new one
Apr 04, 2009 | Computers & Internet
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Monitor Turns off
Have you turned off the hibernation?, that would be your first priority. Check the settings again to make certain in the Power configuation has been set to never for all settings for both power abd battery for the time being use them and then try again?
Sep 11, 2007 | Dell Inspiron 6400 Notebook
HP Pavilion dv6000z Notebook Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
