Question about Teac Audio Players & Recorders
Blown transformer I have a blown Transformer, from a SR-L200i, Teac Ipod radio/ docking station, PN E190246 HF-48224T 2806 I need a new one, can you advise where to get it..
  • MikG Jan 12, 2009
    Have you heard anything on this one yet?
    I have the same problem (HF) E190246 HF-57224L2TN. I assume that the HF stands for Hang Fung Electronics? I have surchased high and low for this one with no luck. It's for my under counter LCD tv / Radio. From GPX
  • MikG Jan 12, 2009
    Scholar:
  • 56 Answers
Greetings!
GPX just received this transformer in stock, at least for model KCLD8886DT. You can contact them at 314-621-2881 and follow the prompts (I think selection 2) or contact them via email at partsinfo@dpi-global.com. The transformer is $15 plus freight. Good luck!
Rob
Posted on Jan 14, 2009
E190246 Transformer Power ? Secondary Voltage ?
The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Apr 25, 2011 | Teac DC-D2831 CD Shelf System
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
I have lost the AM antenna. Where can I source one as I have no AM reception ?
hi,
you can get a generic AM antenna at radio shack or you can make one, its easy, all you need is a 10 foot piece of wire, coil the wire up in a circle and tape it so its a coiled circle about 5 inches across, leave the two wires hanging out about a foot to connect to the two AM terminals on the radio, the bigger you make the coil and the more coils you make the better reception you will get, turning the loop around changes the reception some
good luck
jm
Jan 09, 2010 | Teac SR-L200i-W Docking Station for Apple...
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
Mar 23, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Teac sr-l200i, the ipod dock just started malfunctioning in the last hour. When I dock the ipod there is barely any sound. This is the case for all my ipods on this unit. The ipods are working on all my...
I had the same problem but with a different TEAC docking product.
My TEAC would not recognize my ipod therefore I was unable to control my ipod via the docking station remote control.
Plug your ipod into the docking station and power down (reboot) your ipod. Once the ipod powers down (in the dock) restart the ipod (yes, while in the dock).
Mar 09, 2009 | Teac SR-L200i-W Docking Station for Apple...
Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Jan 16, 2009 | Curtis KCR2610 7 in. Portable Television
Teac GR-10i table radio
The iPod touch for some reoson is not compatible for some reason. I have an iPod touch 2nd gen and it doesn't work. However it does work with other types of iPod.
Jan 15, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Iphone 3G and Teac SR-L200i-W
You'll probably need a charging adapter like the Scosche Passport, avaiable via the Apple Store.
Aug 06, 2008 | Teac SR-L200i-W Docking Station for Apple...
1,272 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
