Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Jandy aqualink rs4: pool has been winterized with the spa left on. when switched from service mode into auto mode system switches back from spa into pool mode (motorized valve switches back to pool mode). What can be done?
  • Anonymous Mar 16, 2014
    How do I get my balboa spa to switch from sleep mode? I just bought a house with one and have no clue how it works. I filled it and want to run it but I can't get it off of sleep mode?
  • 366 Answers
The only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Posted on Nov 14, 2009
    New Friend:
  • 12 Answers
The valves have a micro switch locatednon them. Either the side or bottom. Its a very tiny 3 way switch. This is used to control the direction of rotation for the valve. Counter clockwise, clockwise and off. Once younfin the switch, enable the off position. This will prevent thenvalves from rotating. You can then put the system back into auto mode and use your remotes as normal
Posted on Jul 19, 2013
How do I turn off time out function on aqua link RS4
push button below auto service and time out 1 time to put it in auto
Dec 12, 2014 | Jandy Aqualink Rs4 One Touch Control...
What is the right switch position to be when i have spa and pool together
If you are asking if you should have the pool or spa button on, then the answer would be pool. Pool mode creates suction from be pool and should be set up to return to both the pool and spa. This setup allows all the water to be filtered and or heated at the same time.
May 29, 2014 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink RS4 Filter pump relay switch location
relay behind lower panel above breakers with red and black wires to it
Apr 13, 2011 | Water Pik Aqualink Rs4 Package - Pool and...
My aqualink rs4 display reads " service mode," how to I get it back to normal function?
This is set out at your equipment. It will be a button you push three times. It will have LED lights next to it. The first position will just run regular, the second is what you have now so you can control the system out at the equipment. Then the last is a three hour time out and will keep the system running as you left it in service mode. Your pool guy will use this to circulate chemical's after he leaves. I could be wrong but I think this is on the left side of your power center at the equipment.
Sep 27, 2010 | Jandy Aqualink Rs4 One Touch Control...
I have a Jandy Aqualink rs unit in the house attached to wires. My problem when I put my unit on auto, I have found it to switch to the spa program and empty the water out of my spa. What do I have to do...
Try this. On the suction valve their is a JVA... actuator and on the end of it their is a small toggle switch and all you have to do is change the position of this. Hope this helps.
Mar 25, 2010 | Jandy Aqualink Rs4 One Touch Control...
JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Jan 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Filter clicks, but won't turn on. Pool lights
put your aqualink into service mode. then select components manually this will override any pre-programmed options
Jul 21, 2009 | Jandy Aqualink Rs4 One Touch Control...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
218 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
