Question about Microsoft Windows XP Professional
I have just upgrade my ADSL1 connection to ADSL 2 using a Thompson tg585v7 router, the vista machine works ok, however the 2 windows XP machines have connections intermittent performance to the Internet often requiring a reboot to fix, then after a while the problem happens again and is consistent on both wired and wireless sessions. off this router. Regards Dean,
  • 3,600 Answers
Your having conflicts with vista software replaace the vista software with windows 7 and your connection problems will go away.
Posted on Nov 26, 2009
  • 981 Answers
You've put a networking problem in as a WinXP issue without describing the network topology.  Perhaps the WinXP systems are set up to use the original connection, and the new router eventually tires of that behavior and cuts those systems off; you can look in the router's logs around the time the WinXP systems drop off for clues.  Look things up, read the manuals, and you will have a better network for your understanding of its operation.
Posted on Nov 14, 2009
HOW I CAN CHANGE DSL TYPE
Not all of the modem has this settings, changing the modulation that your modem is using. You can simply check it from the modem page and look for the advance tab then check for the modulation option then you can select from the modulaiton for adsl stated there. you can choose from adsl, adsl2, adsl 2+ or g.dmt for adsl1.
thanks and please rate this post.
Jan 03, 2012 | Computers & Internet
I am using SPA2012 with TG585v7 ADSL on PPPoE, i am not getting any incoming calls, my out going calls are ok. I have done port forwarding still no solution. When i run same SPA2102 on linksys ADSL it...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
May 10, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Hi, I configured my Linksys WRT 150N Router to block certain URLs. I get the sites blocked on some machines running Windows XP while I cant get the same sites blocked on some running the same XP. Its even...
I was having a similar problem, and solved it by upgrading the firmware of my router. Once I did the firmware upgrade, blocking worked fine. You can get the firmware upgrade by going to the Linksys website, clicking on Support, and then specifying your router model number.
Dec 15, 2010 | Computers & Internet
My zoom adsl x5 modem/router will not let me go wireless
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Mar 09, 2010 | Zoom ADSL X5 Router (5554-72-00)
Limited Connection
shut off the router then turn it back on again.
Jan 27, 2009 | 3Com OfficeConnect Router
Dsl modem/roughter
I have a Belkin adsl modem wireless router operating three machines and it works fine for me main machine on vista one on xp home and the other on xp proffresional
Dec 29, 2008 | Computers & Internet
ADSL 25020 Modem Not Working on Vista
Go to Network Sharing Center. Select Undefined Network click on customize click on IP4 enabled IP6 Enabled then go to advanced setup type IP address 192.168.1.1 on all fields. restart computer completely unplug and connect power supply again to router. that's it. If it fails go to http://192.168.1.1 type username admin password admin then on sidebar click on advanced setup click on WAN then select first row from top.. select next then click on Bridge Tnen Next Seav and Save/Reboot. Close Browser. wait for 2 mins . then dial PPPoE manually from Network Sharing Center.
Sep 26, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Lost Wireless Connection DLink G604t
So if your other 2 laptops (WinVista) is working then that means that the wireless on your Dlink is working fine. Its possible that its a problem with the settings on the winxp laptop. does your winxp laptop have a builtin wireless adpater? What does it say on your winxp laptop is you will try to view the available wireless network?
Jul 29, 2008 | D-Link DSL-G604T Wireless Router
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
Microsoft Windows XP Professional Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
