Question about GE Profile Spectra JGBP90 Gas Kitchen Range
164D3871P001 Need to know how to clean oven - GE Profile Spectra JGBP90 Gas Kitchen Range
Clean oven on kenmore range
LOCK OVEN DOOR AND TURN SELECTOR TO CLEAN. APPROX THREE HOURS LATER OVEN IS CLEAN. CLEAN UP ASHY RESIDUE.
Nov 10, 2013 | Kenmore Ovens
Need to know how to use the "self cleaning" method for my GE Profile Spectra oven. Also would like to know how to use the convection part of oven also. Thank-you for your help.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Apr 15, 2011 | Ovens
Bought a GE Gas JB series oven used; need to know how to use the self-clean
heatman101
Jan 09, 2011 | GE Ovens
F8 code on my frigidare double oven after cleaning with self cleaning oven ....know this is in the lock but need to know how to fix it myself left it unpluged overnight plugged back in and its still f8...
Hi
Yes F8 is oven door lock error warning.
You need to physically check the door switches and lock relay, these will be inside the oven casing.
It is probably not the easiest of diy jobs as everything is concealed.
Dec 16, 2010 | Ovens
Need to know how to set self cleaning ge p7 self cleaning oven
heatman101
Sep 24, 2010 | GE Ovens
What should I use to clean the tough spots in the oven
Use Easy Off only.
Self cleaning leads to malfunctioning parts.
It is a nice feature that does not work well.
May 23, 2010 | GE JKP15 Electric Single Oven
(1)Cannot find location of model number. (2)Cannot locate service manual. (3)Need to clean oven. I believe the ovens (double/wall/electric) were installed in, or around, 2003, 2004. Simple want to know the...
need to know what model and brand you have.
most newer ovens only need you to remove the racks, then push the button for self clean, push the button to allow about a 3 hour clean cycle and it should then go into a lock the door mode. after the time is up it will need to cool down and then you should be able to open the latch and wipe out any burnt residues.
Dec 31, 2009 | Ovens
I need directions for GE gas wal oven
Call the mfr and let them know what you need. You can clean the porcelain of the oven. Just don't use too much elbow grease when scrubbing. Use a steel wool pad as easy as you can but hard enough to clean it. If you scrape of the porcelain, then it will be hard to clean from now on. It is like taking the pocelain off your teeth. It will catch everything coming and going.
Jan 29, 2009 | GE Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
882 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
