Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
MFC 440CN fax machine
Paper won't feed even though it seems to be loaded fine.  Can't make copies.
    Sniper:
  • 58 Answers
Is this through the ADF (top feeder) or from the paper tray? Either one can have some build-up on the paper feed rollers and would have to be cleaned.
Posted on Jan 22, 2008
Paper will not roll into print positions - brother mfc-j430w
Check the green paper-size end guide inside the paper tray, it may be too far forward. There's a mark for letter-size paper (LTR) and I have my guide set right at the mark even though it seems it ought to be shorter. Be sure your paper is back up against the mark. You might also buy some different paper and see if that's the problem. Sometimes cheap paper will not feed right (I use Staples copy paper in my ink jet and laser printers).
May 28, 2014 | Brother MFC-J430W Inkjet All-in-One...
Hi, the printer is saying paper jam when there isn't one. it won't scan or copy from the glass and will copy from the paper feed but only 1 copy and then comes up paper jam again. if you turn the...
there are many spring loaded switches within a printer that monitor the location of a sheet of paper, it is possible that one of these switches got stuck and is the cause of your problem. Printers can be quite difficult to work on, so I would recommend taking it to a local repair shop to have it looked at. If the switch is simply stuck it may be a quick and easy repair.
Another thing to look at is to make sure all of the rollers that feed the paper through your printer are moving, if one is stuck it could be giving you the same error.
May 05, 2011 | Office Equipment & Supplies
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Paper feed doesn't seem to work.
The problem is paper feeder mecahnics. Check pick rubber roller at the mecahnics and lubrication, or replace paper feeder.
May 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
HP Officejet Pro L7580: says load paper/won't print
Go to printer and faxes and cheeck the preferences of your printer cheeck the number of copies and all strange that you will saw.
i hope my advice is helpful.
May 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Not grabing paper to print Seem as though the roller feed is not
This will happens when the paper feeder sensor fails. Due to this when give any print or copy it wont feeds the paper you may get the error please load the paper. For this you need to contact HP Customer Support for a service if it is under warranty.
Thanks & Regards Nandu :)
Mar 14, 2009 | HP Photosmart 2610 All-In-One InkJet...
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper feed problem Canon PC25 copier
check where exactly it wrinkle .it is most likely to be from the fuser unite.i.e where the paper comes out .if the fuser rollers is having mark or the paper sepration finger ontop of the roller is bend or loses its springing ability
Oct 07, 2008 | Office Equipment & Supplies
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
145 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
