Question about Sport & Outdoor - Others
I need to hook up 3/4 cpvc water supply line to water meter
I need to hook up 3/4 cpvc water supply line to 3/4 brass female treaded brass water meter .what hardware do i need?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
I went to Home Depot for the same reason.Ended up getting a brass fitting with a cpvc insert that excepted the cpvc pipe to be glued into brass fitting once it was screwed in place.Came out about a foot then used a coupler to join both cpvc pipes so in the future I can replace meter without cutting pipe.Im not a plummer just a home owner who cant afford one so I dont know if I did it right but it works.
Posted on Nov 14, 2009
Received new Maytag Gas Range. I have propane. . After switching the brass aperture to the propane side, there is no fitting to connect to gas line 3/8" female to 1/2" male the 3/8" has an odd thread
The odd thread might be a left-hand thread; fuel gas connectors often are.
As well as switching the air bleeds to propane you need to ensure the right gas pressure is being delivered to your stove.
A local plumber's merchant or similar should be able to supply the fittings you need.
Feb 04, 2017 | Grilling
Just installed a MQ 3 -35 in my home in order to improve low city supplied water pressure (35psi). Now my home pressure is at 75 to 80 psi, too high. How can I regulate the pressure down to 55-60 ps
proper way is to install a water pressure regulator and due to potability reasons it needs to be brass ,bronze, stainless steel, or CPVC plastic , (no steel or cast metal) of course the less high tech way is to plumb a valve from pump outlet back to its inlet and adjust valve to max pressure setting you want at max demand , I don't recommend this method as it wont be able to give you a constant pressure regardless of demand as the first method will , Note: some water regulators are a "relieving" type and require special install methods and maybe three lines to it
Aug 16, 2015 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Karcher 3.190 breaks hose coupling connector
use high quality brass fitting, low quality brass will break also,replace male and female side with matching brands
Mar 30, 2014 | Karcher Garden
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
Water & Ice Maker installation schematics. Need diagram of back of refrigerator
You need to get the model number... look up the DUAL water valves (which seem to be missing) and hook up the water & ice RESPECTIVELY
Watch those supplier videos...
Those new press connectors are a snap to
use (and release)...
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
kit LIKE THIS... (can't tell w/o model number)
Amazon com 2181730 Quality Replacement Dual Water Valve Kit for...
Carnac the Magnificent
May 21, 2017 | Amana Refrigerators
For some reason, after 5 years, a small leak has developed where the hot water exits the autocirc2 tank when you turn the hot water on. I removed the fixture where the plastic tubing hooks on and the only...
It's true, nobody has 100% perfect answer for broken stuff.
Open following link for some autocirc resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
If I understand correctly, you removed supply line that connects autocirc pump to the hot water shut off valve.
Buy standard sink supply line at local box store or plumbing supply.
If memory serves, the supply line is 1/2" IP thread that connects to pump and 3/8" Compression fitting that connects to shut off.
You might try using thick-bodied white teflon joint compound to help seal the connection.
I use rectoseal on threaded connections and tubular drain connections to ensure forever seal:
http://waterheatertimer.org/images/rectoseal-006-400.jpg
If brass part of pump is cracked, then autocir may be bad.
I have no idea how to permanently fix a broken brass water fitting, and would suggest replacement at that point.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | Laing Thermotech Autocirc Undersink...
Connect water line and drain line
The supply line connects to the brass screw in fitting on the bottom left corner under the washer.
When you buy a dishwasher supply line kit, it will come with any adaptors needed. Unless you are using the steel braided line you will need to use teflon tape on the threads of the line. If you are using the SS line kit, you will only need tape on the adaptor.
Here is a pick of the line and the adaptor.
The drain line is attached with a typical hose clamp like this.
It is attached to the stub out on the garbage disposal if a GD is installed. If not then it is attached to the stub out on the drain pipe for the sink, like this.
Here is a pic of a drain line installed on a Garbage Disposal.
Oct 03, 2009 | Dishwashers
I own a amana side by side refrigerator...I have not hooked the water line up for 10 years...now I need to bring it back into service but notice the hook up appeared to have a treaded female junction more...
Yes there is an adapter. If you purchase the ice maker line kit from Lowes or HD (the stainless steel braided line) they often come with the adapter.
I recommend the steel braided hose as they are flexible, and burst resistant. It will be a simple brass fitting with male end to go to the fridge, and the hose hooks up to the adapter
Sep 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Water Supply Line for Ice maker and Water dispenser is leaking.
Hi, The fitting either needs tightened or changed. Is this a brass or plastic fitting?
If the supply line is still ok and not brittle, you can go to your local hardware store and get the new fitting parts. If it is brass, be sure and get the brass insert that goes inside the tubing as well as the compression ring.
Please let me know if I can assist you further.
Vic
May 28, 2009 | GE Profile PSS26NGS Side by Side...
Sport & Outdoor - Others Logo
119 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
