I have a Mitsubishi WD-62531 LCD rear projection TV. I recently replaced the bulb because the "lamp" light illuminated. It worked for a little while, then the "lamp" light came on again. I reseated the lamp and it worked for a couple days. This cycle repeated fro a few times. Now it will not work and I hear a buzzing and clicking sound coming from the lamp area after I have reset the "Lamp" fault and attempt to turn the unit on.
  • 19,396 Answers
Hi.
You need to replace the ballast board. This is the high voltage board connected to the lamp.
Before replacement the board must be tested by a technician, reading DC voltage in and high voltage out. This board must not be replaced by the home user.
Part number is 938P055010
Here the part: TV Modules - Light Engines - Electronic Parts Home Shipping Form ...
Alternatively call Mitsubishi at the number listed on the owner manual to get a quote on repair.
Regards.
Posted on Nov 14, 2009
Red status light on
lamp has failed. Check your manual for removal instructions but you can find a new lamp with a good warranty here. Mitsubishi DLP TV Bulbs
Aug 29, 2015 | Mitsubishi WD-62531 Projection Television
Were is the lamp cover of the mitsubishi WD-62531 at so i can change the lamp
It's on the back of the tv, located on the left while facing the back. There are 2 screws holding the lamp cover and 2 more holding the lamp.
Sep 14, 2010 | Mitsubishi WD-62531 Projection Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Just replaced bulb two days ago and now theres no picture
there could be a couple of things causing thie, make sure the lamp is all the way plugged in, make sure the lamp door is on and completily closed, also if a fan is stuck and cant spin, also the ballast can cause this, that is the small board that lights the lamp
Jan 11, 2009 | Mitsubishi WD-62531 Projection Television
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Televison & Video Logo
Top Televison & Video Experts
