Question about RCA Televison & Video
Rca d52w27d no convergence in the set up menu cant run the convergence
  • 145 Answers
Some rca models have the convergence as a seperate button on the front or side of unit. sometimes if unit has guide plus+, unit wont have that option. try on your tv factory remote, with tv on, push menu, 7, 1, go back, tv. that is the code to reset your computer in tv.
Posted on Nov 14, 2009
2 Suggested Answers
  • 145 Answers
SOURCE: rca d52w27d no convergence option in the set up
try unplugging and plugging back in waiting 2 minutes in between. get factory remote and with tv on press....menu, 7, 1, go-back, tv.......... then press menu, 7, 1, go-back, who-input. this will reset your tv to factory
I cant see the color on the tv to set the color back because I cant see the menu settings
If you leave it unplugged for a while, all settings should go back to default
Jan 20, 2012 | RCA Televison & Video
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Convergence adjustment
  • Screen looks 3D
Apr 30, 2010 | RCA P52926 52" Rear Projection Television
Rca television model #D52w27d does not show convergence on the menu setup on the remote. The television is showing alot of green & red, it is showing double vision. e-mail ednaroberts20@yahoo.com. We...
You have a Blowed fuse on deflection board It will be bottom left hand side board it has FBT flyback Transfomer on it and Right hand side of the FBT is 3 Fuses in a Roll they are small brown looking caps But they are fuses .06amp fuse it will be the one in the Middle FL231.
Jan 10, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w27d no convergence option in the set up menue
Nov 14, 2009 | Televison & Video
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
Convergence
if you cant converge from menu. your convergence ic is going bad.
Jun 02, 2009 | RCA R52WM24 52" HDTV Projection Television
Warped picture and looks like you need 3d glasses
Check FL1231, DP1231 and C1230 on the deflection board thats usually what causes the option to drop off the menu
May 10, 2008 | RCA R52WH76 Television
Televison & Video Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
