Question about Cell Phones
Trying to fix washer i flipped it upside down and it leaked oil will i have a problem?
  • 1 more comment
  • stalhu Nov 14, 2009
    she flipped it...did you understand the question?
  • A Miller May 11, 2010
    Good question. How does your wife feel about oil on the floor?
    Well, no actually, I didn't understand your question, but it did bring interesting animations to my imagination ... Think about it, the heading is "Generic Problem ... Cellular Phones" and the comment talks about a "flipped washer" (weighing more than 100 lbs) and your question is "will I have a problem (with the oil that leaked out)?" My comment was "How does your wife feel about the oil on the floor?" When I think of "flipped" I'm thinking about a coin, or a burger, or an acrobat, not a washing machine. I am not laughing at you, the picture that came to mind was humorous, I think you will admit. You have entered into a very ambitious repair and my hat is off to you for that, my friend. It is never easy to repair awkward, bulky, heavy equipment in a limited and confined space. I'm sorry it fell (flipped) and I am very happy no one was hurt as a result of the accident. As far as answering your question, you don't say anything about its make, model or age nor the amount of oil that spilled. I would say that it was probably a small amount and it probably came from a breather in the transmission. Replacing the oil may be more of a job than you want to take on. I don't know but would guess that replacing the oil might require removal of the transmission. I would guess the transmission contains 10 or so ounces of oil and I would further guess that you lost less than one ounce - but I don't know anything about these figures. Presumably, the breather is on the top of the transmission and probably not accessible otherwise, though, there could be a filler attachment on the transmission. I don't know these details about your machine. I am NOT a washer transmission expert and I don't propose this as a SOLUTION. I am posting this as a "Clarification Request". There are other volunteer's here ("Here" is a Virtual Place) who will see your question and the comments that have been posted and you will probably get better direction and instruction from one of them. If this were my machine, I would finish what ever repair I was doing (replacing the belt?). I'd look to see what was involved in replacing the lost oil (I presume this is 90 or 120 weight gear oil). If I could reasonably make that repair, I'd try it. I would not remove the transmission! My main concern here is getting it back together AND keeping all my skin in place, no blood loss. Then there is the concern for the "Law of Unintended Consequences". I don't want to make things worse because of something I had not anticipated. If I couldn't get the oil in pretty easily, I'd put the machine back in service. My reasoning is my machine is not new and nothing lasts for ever. Your thinking doesn't have to parallel mine. I am certainly not trying to make light of your situation, your ability to effect this repair, or you. If I offended you in any way, I am very sorry. It IS not my intention, as a volunteer worker at FixYa.com, to offend people who post questions. If you are still with me, thank you for reading my comment and thanks for posting your comment at FixYa.com. a
How can I fix my pool cleaner from flipping upside down during the cleaning process?
Remove weights, Thoroughly clean cleaner, backwash filter system to get optimum suction. Check filter system for optimal suction..., ie. leaks, excess debris, clogged baskets, strainers, etc..
Apr 11, 2016 | Pool & Spa
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
Feb 20, 2015 | Televison & Video
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
What kind of oil do you put into a Excell pressure (exh2425) washer pump? Do you use the same as engine oil (30 w)?
Pressure washer oil
I took this picture of my power washer so it's easy to explain the oil.
The oil is different for engine and pump.
The pump oil is 20 or 30 weight non-detergent. SAE20 or SAE30 motor oil. The level of the oil comes up about half way. There is a plastic viewport on side of pump ... oil comes up half way on viewport.
The engine oil is 10W30 motor oil. It comes up about half way or a bit more on dipstick.
To remove oil from pressure washer, do not turn engine on it's side or turn engine upside down or motor oil will run into the carburetor. You might wonder how I know that. Afterward, the carburetor needs to be cleaned out.
To remove oil, you can tip engine to the side but not so much that oil runs up into top part ... to remove the rest of the oil, you can use a plastic hose
Oct 19, 2010 | Garden
How do i flip my computer screen upside down
1.
When the computer screen flips upside down, make sure not to burst a blood vessel in anger. Try keep checking.Just be calm and you will be able to fix this.
Simply press CTRL + ALT + Up Arrow to fix the screen. To prove this works, press CTRL + ALT + any arrow key to flip the computer screen in any direction you want.
Thanks.
Have a great day.
Sep 16, 2010 | Computers & Internet
Gear box is leaking lube.....repair or re-lube?
There is no trick to replacing a worn gearbox seal.
It is the job for a skilful and sorry.........has to be paid......Techo!
Oct 20, 2009 | Whirlpool LXR9445JT Top Load Washer
Oil leaked out
These are normally sealed - with a tiny weep hole to eliminate any pressure buildup.
You'll need to remove the Gear case, and attempt to fill it using a needle etc... the hole is REALLY small - and they are designed so you DON'T have to flip the machine upside-down for service.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2009 | Kenmore Washing Machines
Washer was stored upside down and all the motor oil leaked out - is it still good and how do I replace the oil?
The easiest way is to replace the gearbox - as it is a sealed design - with a TINY weep hole on the top. You'll need to remove it anyway to attempt the fix.
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Mar 31, 2009 | Motorola Mobility i880 Cellular Phone
Flipped Kenmore over to replace pump now oil leaked out, where?
did you tip the washer all the way over? bad idea if you did. is the washer functioning ok? if so don't worry about it. but no....you cannot put the oil back in. It might be ok as long as it does not leak any more oil. This oil is comeing from your transmission. which controls your agetation and spin.
Mar 26, 2009 | Kenmore 22642 Top Load Washer
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
