Question about Anycom MILOS-9 Bluetooth Headset
I need the code for my milos nine bluetooth so i can pair it
Can i have code
Posted on May 31, 2010
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
How you pair you headset with your pc
With your headset fully charged, and turned off, press and hold the multi-function button, until the blue and red leds flash alternatively. It is now in paring mode. Now, make your PC bluetooth application (don't know which bluetooth stack it has), search for other devices, Select 'MILOS-9', and, if a PIN (or passkey, or pairing code) is requested on your PC, enter '0000' (four zeros). The blue led will flash three times, indicating successful action. If the pairing procedure fails, turn your headset off, wait for 10 seconds, and start it over. From now on, you will need just to turn the headset (and the PC bluetooth hardware) on. They should automatically connect to each other. If they fail to do so, try to right-click on 'MILOS-9', on your PC's bluetooth device list, and select 'Connect'.
Hope you are able to sort your problems out.
Cheers! Carlos
May 06, 2010 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
Need password for milos-9 bluetooth
try 0000 (4 Zeros) if that doesn't work try one of these:
1111, 1234, 9999
Jan 04, 2010 | Insignia Bluetooth Wireless Headphones...
Can not figure out how to connect my ANYCOM Milos-9 to my cell phone. no instructions came with product.
Turn off the Anycom headset. After it is off, press and hold the silver power button. You will see a blue light come on but dont let go off the power button, keep holding it till the light turns red. Then the device will be in pairing mode. Turn on the phone and make sure that the phone is visible in the bluetooth settings. Scan for a device in the phone and you should see the Anycom headset. If it asks for a code to enter then the code is either 0000 or 1234 or 9999.
Dec 27, 2009 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
Need passkey code for bluetooth
The default is 0000 (that's 4 zeros)
Dec 30, 2008 | Radio Communications
Anycom MILOS-9 Bluetooth Headset Logo
350 people viewed this question
Top Anycom Radio Communications Experts
eradiostore
eradiostore
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
