Question about Whirlpool Dryers
There is a rubbing/knocking sound whenthe drum
I have a whirlpool dryer and there is a rubbing/knocking sound when the drum turns. What can I check ?
    Problem Solver:
  • 13 Answers
The sound is most likely from one of the wheels the drum rotates on ( usually the lower one ). The bearings wear and sometimes break and completely fall out from center of wheel. I replaced one on mine at a cost of $5.00 from a local repair shop. Just provide brand and model number when calling to see if they have the part in stock. You should be able to access this wheel by removing lower front panel and reaching. Please note I only had to remove the ring pin ( not the bolt ) to remove the wheel. It will be really tight when putting in new one but with a little force you should be able to manage. Before starting you will definitely want to unplug the dryer and still don't touch the electrical wiring or components. Hope this helps as it saved me money.
Posted on Nov 14, 2009
My whirlpool cabrio dryer is making a loud knocking noise
Check to see if one of the paddles are lose in the dryer drum.
Nov 23, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Smells like its burning and a rubbing sounds!
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 11, 2010 | Whirlpool LER7646E Dryer
I have an Inglis Liberator Heavy Duty Gas Dryer that has this scraping noice that sounds like the drum rubbing on metal and takes an hour or more to dry cloths! Do you know what the problem could be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 04, 2010 | Whirlpool Inglis IP8200 Dryer
Drum makes a rubbing sound when spinning.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 17, 2010 | Whirlpool LGV4634JQ Gas Dryer
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool ler4634jq0
Your rollers probably need replacement. Get a bonified FSP idler instead of a crappy made in asia knock off. Check your drum slide. Rib side down with the belt to the drum.
Dec 15, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
