Question about Vizio VX42L 42 in. LCD TV
L try to connect my pc to my vizio tv,but the tv show me,no rgb signal,the power will be turned off,so can you help me,l dont know how can l have the signal,thank u
  • 66 Answers
Select the right input on the tv with your remote if you havnt done so.
Posted on Nov 14, 2009
Getting a no RGB signal on my vizio tv model #E371VL any suggestions?
Try changing the input on the television with the remote or on the television control panel. Apparently you don't have anything plugged into the RGB connections.
Dec 31, 2014 | Vizio Televison & Video
RGB connection
The video signal comes from the PC do not match with the input selection to tV.
Mar 11, 2012 | Vizio Televison & Video
Trying to connect pc to my vizio tv with video cable (blue) and audio cable. The RGB says "no signal".
Please reduce Display Resolution of your PC so Vizio TV can show its video output.
Let me know what Windows you are running in your PC to guide you more if you do not know how to change Display Resolution.
Thanks.
Aug 12, 2011 | Vizio L32 32 in. LCD HDTV
Hi i got a vizio plasma p42hdtv that was dead i replaced the z sustain board now it powers up new problem is that when it powers up on the screen it says rgb and then a few seconds later it says no signal...
The tv Tuner signal board itself also dead.That the board,where the incomming broadcasting signal cable plug into it.Try website like Ebay.com buy a refurbish Tuner signal board for the replacement.
Dec 14, 2010 | Vizio P42HD Television
NO RGB SIGNAL - VIZIO HDTV TO LAPTOP
I've been online looking for a solution to this problem and couldn't find a fix until today. I just got off of the phone with a Vizio Tech. He told me that some pc's have a way for the monitor to show the screen externally, and that there's usually a button, sort of like the input option on your TV but its an output button for a laptop in my case. It should look like a picture of a TV in and out of each other. Mine was located on the number four key. I had plugged in my wires and put the TV input on RGB. then on my laptop pressed the function key and number 4 key at the same time and what do you know, I had a picture on my screen. I almost gave up on my vizio but love it even more now. I hope this helps.
Jul 05, 2009 | Vizio VX42L 42 in. LCD TV
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Feb 07, 2009 | Vizio L32 32 in. LCD HDTV
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VX42L 42 in. LCD TV Logo
515 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
