Question about Canon imageCLASS D780 All-In-One Laser Printer
Canon D780 Adf Feed Rollers
Do you know where we can purchased Canon D780 ADF Feed Rollers.
Thanks
Jim
We have two canon image class D880 printers in our office. The ADF feeder will not pick up the paper and feed it through the scanner section. We have about 6,000 and 9,000 copies on these. I have cleaned...
Never clean feed rollers with alcohol. Lift the automatic doc. feed cover up. You will see 2 grey rollers. Clean them with 409,fantastic or water. The rollers are available. A pain to put in. Steven
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
It senses paper loaded into the ADF but doesn't feed
There should be a button with settings on it.....ie: 2 sided, collate, etc. There should be an option to change paper settings.......or just clear the whole menu, and go to default to reset the rollers.
Oct 19, 2009 | Canon PC-980 Color Copier
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Image class 780 ADF jamming problem
The problem could be with the ADF rollers. First open the top ADF cover and clean the rollers gently with some isopropyl alcohol on a soft cloth, let dry for about 10 minutes. Also check to see that the top seperator pad is not worn out. This pad should be cleaned as well. If this does not work the ADF rollers and the seperator pad will have to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon image class 6550 adf area document to long error
You orginal feed rollers may be worn out. when this happens, the paper slips and the machine thinks the paper is too long.
You need to have the ADF rollers replaced.
Jul 06, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Feb 13, 2009 | Canon PC-980 Color Copier
Adf
this is a dealer only item, if it's not pulling paper and you can see the feed roller turning,you may just need new feed rollers,but you would still need to order those from you local canon dealer
Sep 18, 2008 | Canon ImageClass D880 Copier
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Canon imageCLASS D780 All-In-One Laser Printer Logo
230 people viewed this question
old marine
old marine
