Question about Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
6 yr. old SubZero 690 side by side fridge side lights are off. Fridge and freezer work. Freezer lights and water and ice dispenser lights work.
  • 553 Answers
Check if your bulb is busted, have it replace
Posted on Nov 14, 2009
    Problem Solver:
  • 7 Answers
I had the same problem - need to replace the left switch on the top. Sub Zero part number 3060140. The right switch controls the compressor and they cannot be switched. One is normally open and the other is normally closed.
Posted on Dec 11, 2009
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Subzero refrigerator is not cold. freezer is fin
you could have a leak in the sealed system,most likely the evap coil.in the fridge section,is there any ice on the left side back wall?look at the back wall on the left side around 12 inches up from the bottom draws,if there's ice there you have a freeon leak and you'll need it replaced.look at your warranty,i believe the sealed system is under warrany for the first 12 years and it's around 650 dollars to do the job.there are two compressors,one for the freezer and one for the fridge.also open the door,you'll see tow switches on top,push them in,does the lights go out and the fan come on,i've seen the light switches stick,the lights stay on and the fridge gets very warm.how old is it?if it's digital is it saying to clean the coil or anything like this?
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
Frezer working fine but fridge not cooling
Mo, open the freezer door and look for the model tag. There should be a manufacture date on the tag. The product has a 2 year complete warranty, 5year parts and labor on the sealed system and 5-12 years parts only. The factory number is 800-222-7820 and maybe able to tell you when it was installed, They may walk you through a couple of items to tell you what was happening.
Nov 21, 2008 | Sub-Zero 690 Side by Side Refrigerator
Disabling fridge lights
Inside the grill there are two light switches One for the freezer and one for the fridge. Pull one of the wires off each connector
Oct 13, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
diane.white@subzero.com
Sep 18, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
524 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
