Question about Craftsman Garden
YARD MACHINES 5.5. electric start 21-INCH SINGLE STAGE SNOW THROWER. Throttle wire is stuck, therefore now the blades will not move. How do I fix it?
  • 44 Answers
Prolly have to replace it, but you can try spraying P.B. lubricant on either end where the cable enters the jacket and working the cable back and forth untill it frees up; this has worked in the past for me on all sorts of jacketed cables, BE PATIENT AND ALLOW THE LUBE TO DO IT'S JOB, if you try to force it you could end up causing more damage to other components
Posted on Nov 14, 2009
WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE SNOW BLOWER VS A DUAL OR MULTI STAGE SNOW THROWER
Single stage has one rotating blade that collects and exhausts via upper shoot.
26373343-4yt0j151ox44pteg2g1nkeph-2-0.jpg Two stage has one blade for gathering into the center and a second that exhausts via shoot.
The two stage works best!!
26373343-4yt0j151ox44pteg2g1nkeph-2-5.jpg Hope this helps?
Nov 26, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Huskee snow thrower spout clogs
Before use spray chute/housing with Pam or WD-40
Also push unit faster to move snow through easier.
Feb 24, 2015 | Huskee 21 in. Single-Stage Snow Thrower
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Yard machines snow thrower 31AE150 single stage
6 Bolts on the Back Cover and your Belt and Wheel are there... If you Tip your Machine up on the Eating Edge, it is easier to gain access to it.
Jun 17, 2014 | Yard Machines Garden
Won't start or turnover
see this was up awhile
so you cant get engine to move at all?
be sure no ice is blocking from moving (move to warm place)
then try
is there oil in it ? if not its set up rebuild or replace
Mar 02, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom
can also take off belt guard (2bolts) and check to be sure belts are on correctly
Dec 18, 2013 | Yard Machines 28" Two-Stage Snowthrower
Garden Logo
115 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
