Question about Vacuums
Dyson DC07 My DC07 has been working fine, but now does not pick up. If you put hand over the tube end the suction is fine. Any ideas. Thanks
This is an incomplete solution. Mine (DC 14 Animal) worked great and then it didn"t and then it did after checking to make sure that all the parts were on securely. I noticed that while the suction sort of seemed normal, it was not strong enough to pick op fine dust from window sills.
The elbow thing near the floor on the right side was not seated properly. I fixed that and it worked great for a while and then lost too much of suction again for no apparent reason. I took a look on the Dyson web sight and they have a trouble shooting guide. The first step is to inspect the main filter and clean it. If I do this again I'll go through the rest of the check process before I clean the filter with cold water as recommended to avoid waiting (12 hours?) for the filter to dry. Mine did not appear dirty and I was unable to rinse out scads of dirt.
I followed the instructions for clearing airways and checking seals... with the canister removed, all suction seems to be fabulous. I'll know in the morning if it really works again after the filter is dry and I can reassemble the thing.
Short version? Try the troubleshooting guide at I'll try to add to this if it works like new again! All in all, it seems simpler to maintain and trouble shoot that any other vac I have owned.
Good luck,
Posted on Jan 17, 2008
I have the DC07 model in the upright position suction is fine but when I drop the handle and go to vacuum it has no suction I've cleaned the filters and hoses for debri and still no suction and once I put...
Hi Chris,
I am very sorry to hear about this issue with your DC07 not picking up correctly. In most cases we may be able to resolve this issue by speaking with you directly and performing basic troubleshooting steps.
Please contact our US Dyson Helpline toll-free at 1(866) 693-9766 or our UK Support colleagues at 0800 298 0298.
Best wishes,
Dyson Customer Service
Oct 05, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07
I'm sorry to hear you're having difficulties with your DC07. For help resolving this, I'd encourage you to give our free Helpline a call - we'll be able to run through some troubleshooting over the phone with you.You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - please have the machine to hand when you call.
Best wishes,
Dyson Online Customer Support
Jan 22, 2012 | Vacuums
My dyson seems to have lost its suction therefore is not picking up anything yet i have found that when my dyson is standing upright it has a little more suction but nothing like how it use to work. This...
Sorry to hear you're having a problem with your DC07. You should be able to resolve the issue by following these simple steps:
If you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
May 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ive got a dc07 dyson just changed the belt on it as i had to since then it isnt picking anything up at all nothings clogged up had it to bits and put it all back together again properly. The hose is...
Sounds like the hose underneath has become detached. Have a look and if its not that come back to me. Also can yo9u check your U Bend is still on as these can come off.
Feb 26, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at
Kind regards
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Clearly no one read the question problem is not low suction but too much
Sep 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My hose tools wont pick up. when hose tools unattached suction is fine and will **** my hand fiercely, but once tool attached no suction..... how am i gonna pick up cat hair from seats now?! its a dyson...
I have a DC04 and the hose tools are a open hole.The only reason they want pick up is they are blocked.If you say they are sucking your hand when not attached.Make sure the hose is not blocked by taking off the cover at the front.Allso check the cylinder rubber seal is sealing the dust container.Thats the only problem i had with mine.Good luck.
Jul 31, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction in Wand Only, (No suction down below).
check the small hose that is under the machine ( it connects to where the brush roller is ) also you can remove a u shaped tube near the bottom of the machine and also another on the right side of the machine near the bottom as well
Sep 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
238 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
