Question about Gateway MX6920 Notebook
My laptop wont search for any wireless networks, it keeps saying that there are no connections available when i know there are
  • dhie ceria Nov 14, 2009
    key MSoffice 2003 please!!!!!!!!
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    Is your wireless activated on your laptop? Is the Network and Internet properly set up?
  • 149 Answers
It is best recommended use a external wireless LAN Card. The problem you are facing with is that your W-LAN card is damaged, you need to change the Capacitor mounted on the W-LAN card but the service is costlier than the new Wireless LAN Card. It is up to you what you will choose. I better suggest you to go for a new one.
Posted on Nov 14, 2009
  • 3 Answers
Well, if that keeps happening try restarting your computer then refreshing, or if you know the network your looking for's name then look it up directly. Else goes wrong, move around where ever you are till you find a connection. You may be not getting any signal because hard walls, etc.
    Scholar:
  • 101 Answers
There may be a switch to turn the wireless on and off - it will usually have an antenna icon next to it.
Have a medion laptop that wont connect wireless
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and than right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network.
Feb 26, 2010 | Medion md40298 Notebook
I keep tuning on my wireless internet on my dell lattitude d600 and my wireless internet wont come on it doesnt show anything wen i press fn and f2
check the error message when you try to search for your network. If it says it cannot find network in range and wireless zero configuration utility is turned off than click on start go to run and type : services.msc, click ok, on right hand side scroll the window to the bottom and you'll see wireless zero configuration >> double click on it >> change the start up type to automatic and click apply then change service to started and click on ok.
Afterwards check if you see your network name or else
try it!
Feb 22, 2010 | Dell Latitude D600 Notebook
Hi, I have acer acpire, model 5534. wi fi wont connect to wireless network. What can cause this problem thanks
Do you see a wireless or network icon in the lower right of the screen, next to your clock? Can you view a list of available wireless networks?
If so and you can see your laptop trying to make a connection on your screen and it just fails to connect, it's likely you've typed in your wireless key wrong.
If not, it's possible you've hit a wireless button or switch and shut your wireless off. On many laptops, there's a switch on the front or sides of the laptop that'll switch wireless on or off. On others, you'll have to look for a colored Fn (function) key on your keyboard. You may have to hold that Fn key and search for a wireless icon on one of other key's that's the same color (usually blue) as your Fn key.
Unfortunatly, I can't find any good pictures of your laptop to tell you exactly where it is. But let me know if this helps!
Matt Audette
www.verical.com
Feb 01, 2010 | Acer Computers & Internet
Have belkin54g wireless router. Now wont connect
Right under screen there should be a button, or the f8 key I think is another one. You can also search you computer for Wireless Assistant which will turn it on for you.
Jan 27, 2010 | Computers & Internet
My wireless wont connect to home, and it shows a big red ''X'' whenever i try. It says that the setting are different, I changed NOTHING and it worked last week.
I'll assume you're using Windows Wireless:
Right click on the taskbar icon + view available wireless networks + change order of preferred networks + delete you network from the list + add network + manually enter the SSID and the security key + ok and exit.
Post your results back here...
Mar 03, 2009 | Acer Aspire 5520-5156 Laptop
The wireless keeps saying disabled.. it wont connect and it cant find the available networks.. there is no problem with the network cos it works fine on the ohter computers/laptops in the house and...
Hi sayeh,
I don't know if some of your IT friends had check the Wireless Zero COnfiguration,lets check it out.
start>run> type in services.msc
scroll down to Wireless Zero Configuration
check the status,
right click on it and click either start/restart
hope it helps
Jun 23, 2008 | Computers & Internet
Wireless not working
First make sure the Wireless LAN card driver is installed. Then go to device manager and make sure the Wireless LAN card is enabled. If not, right click on the Wireless LAN card icon and select enable. Once that is done you should be able to search for wireless networks. If a wireless router is not broadcasting the SSID for the wireless network, the Wireless LAN card will not be able to locate the network during the search. If that is the case, you will need to set up the connection manually. If you can see the correct wireless network during the search but still can't connect to the network, it may not be an open network, so make sure you have the correct security settings for the network you want to connect to. If you did not set up the wireless network, you will need to get the security information from the network administrator.
Jun 10, 2008 | Everex StepNote NC1500 Notebook
Gateway MX6920 Notebook Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
