Question about Grundig S350 AM/FM/SW Radio
Excessive static on AM stations. Waves in and out. Not so on car radio. Is there an antenna to eliminate this?
  • 1 more comment
  • taylorb7 Feb 22, 2009
    the am station worked fine for 2 years and all of a sudden mostly statc.
    thanks.
  • Alfred Santee
    Alfred Santee Feb 10, 2013
    You meed to get a can of DEOXIT and spray the tuning control and while youre at it spray all the pot with it!
  • Alfred Santee
    NOT poytlol all potentiometers with it
  • 3 Answers
Adding to the forgoing excellent suggestions, note that AM, unlike FM, is sensitive to nearby noisemakers like laptop computers, switching power supplies, digital phones and clocks, and to some extent, modern LED and florescent desk lamps. The radio compensates for this excessive noise by making reception less sensitive. Lacking an external antenna (best solution), if you can double the distance from a big nearby noisemaker such as your laptop and its ac power supply, you will reduce the noise by one fourth. Also, rotate your radio until the noise reception is minimal. There are two deep notches in reception off of the ends of the built in ferrite antenna.
Posted on May 05, 2013
  • 27 Answers
Turn on the radio and turn the AM/SW BAND switch to the AM position. MW appears in the display. Use the outer ‘fast’ tuning knob to find stations, fine tuning with the inner ‘slow’ knob
when needed.
• If there is interference from adjacent stations, place the BAND WIDTH control in the NARROW position. If there is no interference, leave it in the WIDE position.
• If there is excess background noise, turn on
the SW LPF switch, which may minimize the noise.
• If a station is so strong that audio distortion occurs, reduce the gain level with the AM/SW RF GAIN control knob by turning it counterclockwise.
• The telescopic antenna does not have to be extended for AM reception. The radio has an internal, directional, ferrite-bar antenna for AM reception.
• To optimize AM reception, swivel the radio until maximum signal strength is achieved.
All of that being said: It's very tough nowadays to receive AM in this 2008 electronic world. If your able install a longwire SW antenna outside, and have access to a good earth ground, you can boost the AM signals and beat the noise being generated all around you.
Posted on Jan 08, 2008
Actually for best results set it to narrow and leave it. Use the RF gain also. These radios are junk really!
Posted on Jun 30, 2008
2014grand caravan fm stations all static
Most likely the antenna lead has come unhooked from the back of the radio. AM stations will pick up with the internal working of the radio, but FM stations have to have a working antenna to work. Also make the antenna is tight to the vehicle .
Nov 09, 2017 | Dodge Grand Caravan Cars & Trucks
Radio has static and tries to pick up just one station a m and fm. 2005 Acura Can it be antennae
The alternator is most likly the problem. If it was ok before and you had the alternator replaced the problem should be the new alternator. The above answer is if static is your problem. If you can not pick up stations there is a good chance that you have a antenna problem.
Apr 09, 2017 | Cars & Trucks
When I try to find radio station all I get is static. How do I use radio function
You need to have an antenna to have your radio stations come in clear. If you just hear static, your antenna sounds like it's not there!
Feb 16, 2016 | Eclipse Audio Players & Recorders
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
Dec 12, 2015 | 2005 Dodge Durango Limited
WHY DOES MY 2004 LINCOLN NAVIGATOR HAVE EXCESSIVE RADIO STATIC ON AM?
As suggested it could be underhood electrical interference. If the "static" changes with increased rpms (rev the motor to find out) chances are it is ignition related and could be literally everything from the alternator to the ignition coil through the distributor cap, but best bet is the spark plug wires (which if still original really should be replaced anyway) or the plugs themselves. If your am static doesn't change with engine revolutions and your fm works okay I would check antenna and the antenna connections at the base of antenna and back of radio. if you cant even get a clear signal on the most powerful AM station in your area, I would bet on some kind of break in the connection between radio and antenna. p.s. if you;ve anything plugged into cigarette lighter or other 12volt outlets in the vehicle unplug them before doing any of the rest!
May 19, 2014 | 2004 Lincoln Navigator
Radio static
antenna wire came loose-check antenna base-follow wire towards radio- Denny
Jan 01, 2014 | Buick Cars & Trucks
1995 buick riviera radio was working fine now all of A sudden radio has A lot of static.
LOOK FOR BROKE OR MISSING ANTENNA.IF ALL IS GOOD RADIO ANTENNA LEAD ON RADIO COULD CAME A LOOSE OR RADIO RECEIVER IT SELF FAULTY.MAKE SURE RADIO BAND IS ON FM INSTEAD AM.BECAUSE AM STATIONS HAS STATIC.
Jul 02, 2010 | Cars & Trucks
Excessive static on am stations when engine is running
two types of noise accur on radio's first is known as a whine,, goes up and down with engine rpm secound is static...normally static is from bad plug wire or plug... you probably have coil packs.. one of them could be arcing.. check it out in the dark of night and look for the spark light. most time good tune up fixes let me know
May 28, 2009 | 1997 Buick Park Avenue
Static radio
This is caused by either a defective antenna or the ground to the antenna.
Oct 28, 2008 | 2001 Ford Expedition
Grundig S350 AM/FM/SW Radio Logo
506 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
