I am unable to connect to my wireless network for the past 2 days. It says there are no available networks in this range eventhough my router is fine and my friends uses the same connection. There is no wirless signal icon(i.e green towers) in my taskbar for sometime now. Even then the network automatically connected everytime i start my computer but after when i tried to create new wireless network connection for some reason my exixting connection was gone and i could not able to connect it again since no networks are available on the view network connection window. My internet works fine thru LAN. Could anyone help me connecting my wireless network again? Thanks in advance.
  • 2 more comments
  • sensekrishna Nov 14, 2009
    Yes, the wifi switch is on.
    Also, there is a pop-up on the wifi icon that says one or more wireless networks detected, but still when i open view wireless network window nothing shows up.
  • cassells3752 May 11, 2010
    have you tried resetting your access point
    is your computers wifi adaptor enabled (some computers have a button or swich on the case that wilol activate/deactivate the wifi adaptor) if this is turned off you will not recive any signal
  • 558 Answers
Got a wireless switch on the computer,make sure its on.
Good luck
Posted on Nov 14, 2009
  • 72 Answers
Check to make sure your AP is broadcasting ID.
Check your WiFi settings to connect to ad hoc an infrastructure networks,
As always, make sure the radio is on and you are not running on battery.
Posted on Nov 22, 2009
It does not make much sense. But it seems the WAP610N has a limit on concurrent connections. We just started to use this device in a small office network. There are about 15 laptops on wireless...
Two possibilities:
1. the router is configured to hand-out IP-addresses in a limited range, e.g., 192.168.1.100 to 192.168.1.110, namely 11 different IP-addresses. When the 12th computer asks for an IP-address, there is none available. Remedy: configure the router to use a larger range of IP-addresses.
2. when an IP-address is handed-out, attached is a 'TTL' ("time to live") value, indicating how long the IP-address remains valid, e.g., 10 minutes or 100 minutes or 1 day or 1 week. If the TTL is too large, then each computer "hogs" the IP-address (even after being shut-off in mid-afternoon).
Remedy: configure the router to use a shorter TTL. Don't worry: when a TTL value drops to 50% of its original value, on a specific computer, the computer will "renew" the lease.
Mar 18, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Unable to connect every two days
SSID is the name you give to the network.
A good key is the code you give to the WPA to secure the network.
Yes, get an update for your router to Revision E here.
Try turning your router 90 degrees to the room that has the computer in it. If you are using Wireles 'N', one antenna needs to be further from the computer than the other for best results. Like this:
| | <---- antennas ----------
router ---------------------------------------| Room |
Apr 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Network is "out of range" only after securing my wireless network
reset your router
should be a reset button on the back,
hold in till the lights on the front flash then its reset open explorer browser
type in 10.1.1.1 or 10.0.0.1
log in as Administrator
add new user
set password while adding new user
save your new settings(write them down too)
run your network wizard again with your new settings applied
test the internet for function
if no function then contact your ISP to assist with connection to internet
all sorted now please rate me MISTERDJ
Apr 11, 2010 | Toshiba (PA3070U-1MPC) 802.11b Wireless...
I got a Netbook, I have been using wireless internet in my home for years but cannot connect to internet with new computer.
In order to connect with the wireless router u need to scan for the available wireless networks in the range .
So if u r using Win XP ,
1. Rightclick on the wireless network connection.
2. U will see view available wireless networks..
3. u will see ur network name
4. enter ur security key
5. Connect
Or if u r using win vista :
1. click on start
2. Connect to wireless network.
5. Connect
In case u need further help , feel free to get in touch .
Nov 24, 2009 | Computers & Internet
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection
check to make sure the wireless zero configuration utility is on ..check from services in the computer and make sure that there is a check in use windows on the network card itself from network connections. Then it should work .
Jun 13, 2009 | Actiontec GT704WG Wireless Router...
"unable to connect to selected network" error
Hi, May be your router is now running a more secure algorith and needs password etc which the old one can't handle. You may have to downgrade your router to the older system..not a good idea.
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Belkin wireless router not assigning IPs for wireless clients
Some routers start handing out DHCP wireless IP's at 192.168.2.100. Try setting the upper limit at .110. If the router is found in a site survey (view wireless networks) but cannot connect, the limitation would be why.
Jan 10, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
531 people viewed this question
David Payne
David Payne
