Question about Magellan RoadMate 800 GPS Receiver
My roadmate 800 will not turn on. When I use the reset switch, it goes to the blue "Logo" screen then nothing.
    President:
  • 1,111 Answers
If its freezing on the magellan screen, there is a special utility from magellan to fix this issue. fortunately i havent had to use it yet so use caution while installing.
you can get the utility HERE
let me know if you need further help.
bill
Posted on Nov 14, 2009
Iphone4 screen goes blue and won't shut off
Hi
Try hard resetting it.This procedure may erase all changes effected on the i phone
Press and hold the power button and the menu button.Wait until the apple logo appears.
Feb 19, 2012 | Cell Phones
Magellan roadmate 800 won't boot up
Try removing the battery and leaving it out for a long time (overnight) and replace the next day and see if that helps.
Dec 16, 2007 | Magellan RoadMate 800 GPS Receiver
Self tests show ok, reset ok, satellite just says searching
make sure the battery is charged up good, then take it outside and turn it on and leave it in clear view of the open sky for up to 30 minutes to acquire the satellites especially if its been reset.
if that fails, reset the unit...turn it on, then slide the reset switch on the top of your 800 to the opposite position and once it turns off, slide the reset back to the normal position and turn it on again and take it back outside and let it in clear view of the open sky for up to 30 minutes.
if that fails..go HERE and get the update for which ever 800 model you have...you will have to sign on to the Magellan site before you can download anything.
if you need more help, just post back
bill
Jul 04, 2010 | Magellan RoadMate 800 GPS Receiver
No map available
It is quite likely that any maps you obtain from others will not work in your GPS as maps are coded back to component parts in the unit ANTI PIRACY codes .Similar to MS serial numbers. It reads ID's and checks against those stored in map. The only option is to purchase new maps for the area you want.
Jul 24, 2009 | Magellan RoadMate 800 GPS Receiver
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
Mar 16, 2009 | Magellan RoadMate 700 GPS Receiver
Frozen screen
I have a Solution for this Problem,
i have a Software
Any need this contactme i don't know how to post the file,
Fabian
Apr 25, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Apr 02, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Dec 18, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 800 GPS Receiver Logo
314 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
