Question about GE Microwave Ovens
How do I uninstall a GE Spacemaker XL 1400? We need to remove the microwave from the mounting brack.
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
SOURCE: GE spacemaker xl 1400, lights on bottom won't work
To Person who answered Best Solution above,
This worked nicely thank you.
After removing my circuit board the long silver strip was intact, however where it makes the turn about quarter inch, the solder or foil seam had a break in it which I filled-gap with solder.
My guess is if the "foil" or thin 2" long strip is serving as a fuse, it would still melt again even with my solder on the shorter section, in event of overload. Also seen on the plastic area directly behind where the circuit board would mount, and where the "foil" was blown, was a small blackened area as evidence of the blown foil. 2 new bulbs and all is well again Thanks!
Posted on Feb 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
SOURCE: ge microwave spacemaker XL 1400
I did research and found out that the GE Magetetron (sp) are notorious for going bad. I called and it was still under warranty - 10 years, but i needed to pay for labor. That ran me $180. The part was $125 but would have taken my time to install, plus I didn't want to deal discharging the capacitor.
Posted on Apr 14, 2008
  • 32 Answers
SOURCE: Remove mounted GE Spacemaker Microwave
There should be 2-3 screws thru the floor of the cabinet above the m/w that secure it in the front. Once those are removed the m/w will slide straight out on rails mounted to the wall plate.
Posted on Dec 28, 2010
The door handle on my GE spacemaker xl 1400 microwave is broken (plastic). How do I fix this.
By replacing with new one for sure... You can find them on amazon, here: Amazon com ge spacemaker xl handle. I hope this was helpful. Cheers
Nov 14, 2010 | GE Spacemaker JVM1740 Microwave Oven
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave spacemaker XL 1400 stopped heating. 8yrs old
heatman101
hdj
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl 1400. The lights on the
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove ge spacemaker 1400?
You can download GE owner's manuals and installation instructions here.
Aug 18, 2009 | GE Microwave Ovens
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with www.martinmicrowave.com for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
IF THE UNIT IS STILL UNDER THE 90 DAYS BRING IT BACK TO
WHERE YOU GOT IT BEFORE IT STARTS A FIRE!!
Jan 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
195 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
