Question about Maytag MAH6700AWW Neptune Front-Load Washer
Loud noise when the water is draining out and it locks the door and stops and wont let you open it
  • Maytag Master
  • 19,396 Answers
It is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
the pump is accessed removing a panel, usually at the front side of the machine.
Steps are explained on user manual.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Posted on Nov 14, 2009
My frontloader washer wont shut off and the water wont go in. we cannot open the door. How do we fix this. It is only 2 days old
This is a warranty situation. Contact the seller. Otherwise you can take the panel off under the door. There are three screws on the bottom edge. You lift and pull the panel off. You can then see the drain plug and you unscrew that. If you do that though you will get ALL the water from the tub to spill out on the floor.
Jan 30, 2015 | Whirlpool duet Washing Machines
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
During the spin cycle the washer makes a loud noise and now it wont spin or drain water
If the 'loud noise' water sloshing you should first check that the pump filter isn't blocked. This sometimes stops the pump altogether. Coins, etc..If the noise is metallic it could mean bearings...Check the pump via the small door at floor level...Mind the water inside the machine. You may be able to drain first with a small hose which is inside the pump access door.....Nomess
Apr 15, 2010 | LG WM2496H Front Load
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
127 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
