Question about Electrical Supplies
How do I remove drill bit from chuck attachment?
Tool store couldn't figure it out either. Is it stuck? Malfunctioning? Attachment is for their cordless Impacts. 1/4" hex steel.
  • 44 Answers
Pull up (away from tool) on collar where bit enters tool, the bit should slide out easily; if not try tapping firmly (NOT HARD) on the bit with another bit or similiar object before or during pulling collar
Posted on Nov 14, 2009
How to remove a drill bit from insert of screw that holds on driver on an elecctric drill?
do you have the "chuck key"? this is the tool you will need to undo the chuck (part which holds the drill bit). it is often stored in holder in handle of drill. If you dont have chuck key you can improvise using 2 slot head screwdrivers: insert one into one of the 3 holes around chuck, then insert the other into the teeth around check and lever against the 1st screwdriver.
Apr 06, 2015 | Drills
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
I have a Chinese bench drill bought in Australia. The chuck was not attached at purchase. Looking at (American) videos on removal/attachment of chuck, the tapered spindle is part of the chuck. On mine, it...
open the chuck full open and check to see if theres a screw holding that taper in place inside the chuck. maybe you can figure it out from there.
May 23, 2017 | Drills
I need a manual for Ryobi HT20VSK
The multi tool has no "chuck", it uses collets to fix the bits to the tool. Once the knurled cap is loosened or removed, the collet and bit can be removed. If the cap has been overtightened or left in the tool for an extended time, you can remove it by gripping the shank with pliers or vise grip and turn it to release the collet and bit.
Dec 29, 2011 | Ryobi Drills
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
How to fix the bit
If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
Jan 09, 2011 | Makita & 1/2 Inch Drill
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
How do I fit drill in this machine please? DEWALT D25113K D25113 3 MODE SDS
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
Jan 19, 2010 | Dewalt D25213k D-handle Tri-mode Sds+...
Black & Decker Quattro, drill, won't tighten to grip drill bit.
give a good coating of oil then clamp chuck in a bench vice or alike and using short bursts with it set in the forward direction to free the chuck
Jul 07, 2009 | Hand Tools
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Electrical Supplies Logo
171 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
