Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
  • 145 Answers
Yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Posted on Nov 14, 2009
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Picture won't come on
1. See the ugly red color bands on the television set? These can also occur in blue and green. We're going to fix these!
2. Front shot of the television. Their are two screw holes on the front of the unit near the edge of each side right next to the speaker grille.
3. Close up shot of the screw hold. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
4. To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. (see picture) Loosen the cables attached with the twist ties and set the front cover to the left side.
5. With the speaker grille and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
6. This is a picture of the inner electronics of your Sony Rear-Projection High Definition television. The little black box towards the front of the unit is where we will concentrate our time as it is the control for the voltage & convergence adjustment.
7. When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment. The colors are labeled below and from left to right are blue, green, and red. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines. In my case, the red just needed to be turned 1/8 of a rotation to be back in adjustment. Do not turn to quickly or abruptly or you could possibly damage your TV by varying the voltage too quickly.
Mar 24, 2009 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Older 90's projection screen. 52 inch
Try opening up the front cover under the speaker outer cover, most speaker fronts should just pull off if you don't see any screws holding it secure near the side close to the front cover. Then there is about 4 or 5 screws that hold the front inner cover on. You are looking for a small black box with 6 adjusting screws . Three of these are for adjusting the focus and three are for adjusting the amount of current going to the CRT's. The markings are very small but you can try turning the Blue screw down and that will decrease the blue ( marked with a B). But if this just makes the other colors seem more powerful you may have a bad blue CRT. There is adjustments for three color CRT's ,Blue , Green and Red, try playing with the Blue and try to get it the way you think it should look but if the Blue just does not want to work right the Blue crt is probably gone.
Sep 10, 2008 | RCA P52926 52" Rear Projection Television
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red Bowed Lines / Red Hue
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Californian.
Jun 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Thin red horizontal lines across screen
While looking at your TV, remove the bottom right speaker grill. There you will find a cover held by a couple of screws. Remove the screws and behind the cover you will find the "focus pack" which is a group of 6 adjustment screws. The top screws adjust (in order from left to right) the brightness of Red, Green and Blue.
What you will do preferably at night (or with the room dark) turn the top left adjustment screw (Red) all the way to the left and then gradually turn it to the right until the point you can see the retrace line and then turn it slightly to the left until the retrace line disappears. That's it! You can do this for all three colors - if need be. These do go out of adjustment every now and then. The 3 screws on the bottom are to focus the colors individually to minimize "bloom" on the screen. It's best to be in service mode on your TV when doing this OR open up the cabinet and cover (with something) the other 2 colors while you adjust the focus of the color you're adjusting.
Good Luck!
S
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony kp-51w5510 rear projection tv convergence
Lateral red or blue movement is accomplished electronically
via convergence alignment circuitry controlled by STK type IC's
Replace them both for reliability, then adjustments will work..
Nov 26, 2007 | Sony KP-51HW40 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
215 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
