Question about Water Heaters
I have a 96 mazda rx8 and just got a chk engine lt that went off but now the motor is idling rough and it stumbles off idle. ichecked the ecm and the code i got back was uo100 lost conn w ecm/pcm mod a any advice ?
    President:
  • 3,433 Answers
I believe the 02 sensor is on death row. have it chked or change. Good luck. Changed is recommended.
Posted on Nov 14, 2009
I have seaward F1100 ON MY SAILBOAT. I run about 1.5hrs idling. and I had about 100F WARM WATER. Is it normal?. I felt,it use to be get more higher temp, I am not sure....
engines on boats should have a thermostat in the system as they are the same as car engines and require an operating temperature
although they use the surrounding water to cool the engine , I would think that if there has been a change ,then I would be looking at the thermostat stuck open or if you have a intercooler system then a problem in the intercooler system that is allowing the engine to operate at the surrounding water temperature.. the thermostat may be in the inlet to the intercooler.
100 f is the same as 32c which is around water temp in oceans and rivers.
Jul 26, 2015 | Seaward Marine Water Heater 11 Gal Front...
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
POILET LIGHT WILL NOT STAY LIT
tip of thermocouple not touching the flame enough..or need to replace entire pilot assemble chk front of w/h for 800 number for warranty info..
Nov 25, 2010 | Rheem 36" Water Heater Thermocouple Kit
I have a Rheems Criterion Furnace and the main blower does not kick on any more. The ignitor coil glows, the burners kick on along with the venting fan and stays on for roughly 1 minute. The main blower...
Yeah i would change out that board .Should be a 3 amp fuse so maybe as simple as that but if not a cycling blower motor is a tell tale sign of curcuit board
Nov 21, 2010 | Water Heaters
Where is the thermostat in my '05 trailblazer? The check engine light is on and the code is for the coolant system so I changed out the coolant temp. sensor and it is still on so i want to check the...
The thermostat is located on the drivers side of the engine block under the intake manifold. Is the code a p0128 thermostat regulating temp code coming on if so the thermostat should fix it.
Feb 22, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Wilo 3speed recirt pump for my wood stove
I wasn't aware that you would put a citculating pump on a tankless water heater, but as long as the arrow goes in the direction of the water flow that is how it needs to be,, putting a circulator on a tankless kind of goes against what it is for, the tankless will never shut off and once it is on how will it ever satisfy itself to shut down?
May 26, 2009 | Grundfos RCP-96 Recirculation Pump for...
3 speed Recirculation pump lost middle speed
It sounds like you might have had a power surge and burnt the windings on the medium speed. If it is bothersome, you will need to replace either the motor or the whole pump. (not sure if replacing just the motor is an option.)
Mar 05, 2009 | Grundfos RCP-96 Recirculation Pump for...
Water Heaters Logo
59 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
