Question about HP PhotoSmart 7960 InkJet Printer
Printer cartidges failed
My printer says "printer cartridges failed. Replace all cartridges." Do I have to have all the cartridges in to run?
  • 855 Answers
All cartridges should be installed even if empty or you will get a failure. It will try to work when ink is out but cartridge has to be there.
Posted on Nov 14, 2009
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
PRINTER SHUT DOWN INK CARTRIDGE WILL NOW MOVE SO I CAN REPLACE IT I HAVE ALREADY UNPLUGGED THE POWER FROM THE PRINTER AND REPLUGGED IT IN
> cartidge will now move
If you mean will NOT move ...
Turn the printer on.
Open the cover over the ink-cartridges.
The carrier should slide to a position where the cartridges can be removed.
If it does not slide, then the belt that pulls the carrier is broken, or it's no longer connected to the carrier.
If all else fails, replace the printer -- try to find one that uses your existing ink-cartridges.
May 07, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
It says check print cartridge
first of all turn off the printer ... remove the cartidge.... try to clean the slots where the cartidges gets installed as well you will find dotted bronze spots on the cartidges try to clean it... turn on the printer and inser the cartidge... if u still get the error the msg for both the cartidge try putting in a new cartidge id you can and if still there is the messag if might be th problem with printer.... replace the printer....
Apr 30, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printing out photos on a Photosmart A626, and all of a sudden it came up cartridge failed, replace cartridge but it still had 3/4 full.What's wrong
try cleaning the connector or contact point ont the printer to cartidge you can easily find the thing i'm talking about when you try to remove the cartridge from printer hope this helps
Jan 09, 2010 | HP PHOTOSMART A626 PHOTO PRINTER
I have poor print quality on my Lexmark 4550
That obviously shouldn't happen. Did you print an alignment page after you inserted the new cartridges? There could also be some clogged nozzles on the new cartridges. If you haven't contacted Lexmark technical support through www.lexmark.com, suggest you do so.
Aug 05, 2009 | Lexmark X4550 Multifunction Wireless Color...
Problem with refilled HP 27 cartridge
remove some ink from the cartridge and clean the contact point of the cartridge and inside the printer, then hold the cartridge. when the cartridge not drop ink fix the in the printer
Feb 27, 2009 | HP Printer Cartridges (Complete List): ,...
Dell 924 all in one printer cannot remove low ink warning
This happens if you are not using the Dell ink Cartiridges. However there are few work arounds on this issue.
Firstly, Please try to remove cartridges and then clean cartridge slots and make sure that printer is OFF and completed disconnected from Computer. Remove the cable between Printer and Computer while you do this.
After that restart the computer and then try to reconnect every thing and check if this happens
if else, then open the printer properties or printing preferences and locate the option that says Calibrate the cartidges. and do the calibration of cartidges. Calibration is compulsory once if you replace the ink cartidges.
if still fails then reinstall printer software. This should resolve the issue.
Thank you.
Dec 31, 2008 | Dell 924 All-in-One InkJet Printer
Cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Replace color cartridge
Access your printer properties and try preforming a print head or printer cartidge clean and on the machine try the print cartridge aligniment procedure.
If after you try both of those I suspect there is an issue with the print head.
If that is the case an ink jet printer is not worth repairing.
Dec 20, 2007 | HP PhotoSmart 7760 InkJet Printer
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP PhotoSmart 7960 InkJet Printer Logo
410 people viewed this question
Seeker5211
Seeker5211
