Question about RCA P60920BL 60" Rear Projection Television
Covergence and Bowed Picture Problem
Turned the TV on today and found that all three of the colors are off the same amount in convergence and that the picture is bowed narrower in the middle. What can I do to reset the TV or is it possibly a resistor or an IC chip? Thank You for any help you can provide.
  • Lukesav May 18, 2008
    I have the identical problem, tv was fine when i was home on lunch, turn it on after work and all 3 colors are off in the same way the hour glass look. then i shut it off and it blew ther fuse, replaced it and i still have the convergence problems and a small whine!!! so how do i get to the convergence adjustments?
    also where is the ic i've seen described as the cause?
    Genius:
  • 1,030 Answers
Can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Posted on Jan 08, 2008
The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I had 3 pictures in 1 and a bowed 3d screen. I replaced the fuse and re soldered the flyback. The picture looks good now but I still have the 3 in 1 picture?
The problem in in the convergence circuit not the horizontal area. There should be 2 large black ICs inside marked STKxxx. These are the convergence ICs. Try resoldering the pins on these first. Should that not resolve the problem, replace the ICs.
Please keep us posted on your progress.
Dan
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
Model 51S715: 2 issues: (1) Screen is bowed at top...left and right edges turn down and are black. (2) picture color will turn green randomly. If I turn tv off and leave off for a while the color goes...
Ur tv have a problem call convergence,it dying about to be dead.The tv convergence board 2 STK Convergence ICS and some or all it resistors require changing to solved the covergence problems.U have tools,soldering iron,solders and know how to do soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
I have a HCN4727w samsung. Red/green shadowing. Bowed image
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Samsung HCN4226W 42" Rear Projection...
Bowed picture colors off
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Nov 02, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Colors out of porportion, maybe a bulb went out
When you have a 3-d effect. this is called convergence. Is the picture disorted or bowed in. if the picture is bowed in then this is an indicaTION of complete loss of power to covergence curcit. I always check to see if you have the convergence option in the setup menu if you do not then i suggest reading the fl231 problem in the tips and tricks sectionl
Mar 15, 2009 | RCA HD52W58 52" TV
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
178 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
