Question about ASUS V6J-X009P Notebook
Screen fliks change calor to pink if i move the screen or shake it it came back
  • ASUS Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Posted on Nov 14, 2009
  • ASUS Master
  • 13,433 Answers
Sounds like the cables between the display and the mainboard inside the laptop are broken and would need to be replaced. Those cables can be hard to locate, you may want to take the laptop to a repairer who can obtain the parts for it, or contact asus if you are still in warranty.
if this is a desktop computer then just replace the cable between the display and the computer.
Screen started flashing pink
taking the battery out and putting it back in can fix problems like these.
Jan 05, 2014 | Samsung Galaxy S 4G Cell Phone
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
,my pc screen is pink
Symptoms line up with video card going out, or more likely screen going out. if you turn off the computer and turn it back on if its immediatly reddish/ pink tint then its your screen. Can be a bit expensive to fix. also could be as simple as the ribbon cable inside became loose, test this theory by lightly shaking the laptop. if the screen goes from good color and back to pinkish then that is your issue and you will need a repair shop if you are not comftable with opening up your machine! Good luck to you
Aug 30, 2012 | Computers & Internet
When i hit the button so the indash rises it rises fine but to go down it like shakes like it wont go down why is that?Also on the screen when your playing a cd it says "warning vechicle must be parked in...
The shaking problem can be caused by dirt on the rails that guide the screen back into the unit.
To get rid of the other problem, all you need to do is connect the wire marked "HANDBREAK" or "EMERGENCY BREAK" to ground or negative. This wire is usually pink on some radios. But check it out before you just connect anything.
Aug 11, 2010 | Car Audio & Video
Fix Ipod Nano 2nd generation (i no it's a long shot)
my firend took hers in and got anew one when u shake it does it change the siong
May 25, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My laptop screen became pink some pixels are moving
When a laptop screen turns pink it is usually due to a loose or faulty ribbon cable from the screen to the motherboard. If replacing that does not help then the problem is the inverter.
Apr 26, 2009 | Computers & Internet
Background keeps changing everytime i shake my cect i9 phonee
hey yes you can diable the shake feature on both the wallpaper and the music player
1. go to settings
2. hit phone setup
3.on the next menu go allll the way down to the bottom and you will see Gsensor swich wallpaper
and gesensor switch song. trust me its there u just gotta keep scrolling.
4. click off on them both and you have it.
hope this hepls, cuz hat shake is annoying
Dec 31, 2008 | Dual Electronics CECT P168 Cellular Phone
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Powershot A70 pictures have pink tinge
When you say produce a pink tinge do you mean on the view screen on the back or through the viewfinder or on prints or an the computer screen? go into more detail if you please
May 27, 2007 | Canon PowerShot A70 Digital Camera
Problems with the picture on my tv. Pink lines across its screen
take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Oct 15, 2006 | Sony KV-32FX20U 32" TV
ASUS V6J-X009P Notebook Logo
192 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
