Question about Acer Aspire 5100 Notebook
Monitor has lines thru it
Whats wrong with the monitor??? can I replace it
    President:
  • 4,402 Answers
The cost is more than getting a new one. you might be able to find a used one on ebay.
Posted on Jan 08, 2008
Which components need to be replaced when horizontal lines appear?
What horizontal lines do you mean? I can think of several.
- You could have a line of dead pixels on your monitor, this would probably be caused by wear and tear of the monitor, or because it has been handled the wrong way.
- You could be experiencing 'screen tearing'. This is caused by your videocard struggling for a moment.
- If you're running an older, analog monitor, it could be because the cable you're using is getting older and needs to be replaced.
Mar 05, 2016 | AOC CT720G 17" CRT Monitor
Samtron 56v power
solution 1 please replace the horizontal output transistor in near to line output
solution 2 in case you changed the horizontal output when the problem not solved follow this.
monitor line output transformer burned replace them its kept on monitor from mother board to connect thru picture tube. very carefully to change the part because its have a storings voltage capacity in heavy.
solution 3 check the signal cable
May 01, 2013 | SAMTRON 55V 15" CRT Monitor
Pink lines running across screen
Sounds like your lcd screen is bad and needs to be replaced. Try connecting an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the lines, then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same lines as your lcd screen then your video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 07, 2012 | Computers & Internet
Toshiba satilite C6550 has rainbow lines on half my screen the other half is fine ?
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the rainbow lines, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same rainbow lines it means your video card inside the computer has the issue.
May 18, 2012 | Computers & Internet
Toshiba lap top half screen rainbow lines
May 18, 2012 | Toshiba Satellite M35X-S149 Notebook
Vertical colored lines appears on my monitor
Your lcd is going bad, time to replace it. In the mean time verify that it is the monitor or the video card.
Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the laptop. Reboot the laptop and if the image appears ok on the borrowed monitor, then your lcd screen is bad. If the borrowed monitor shows the same way with lines, then your video card is going bad.
It can be any kind of monitor even the old big fatcrt monitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 09, 2012 | Sony Computers & Internet
Top half of my monitor screen shows at the bottom
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
Mar 25, 2012 | Computers & Internet
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
My computer was put in the ship and worked fine before it was left there. All of a sudden now, the monitor has the green lines running all thru it that seem to get worse as I scroll up and down, and when...
Well ... it was a great typo!!! thanks for letting me have a little smile. I wish my typos were that good.
I think were I you, id be taking it back and asking them why the green lines.
...that was retty good though, you must agree, on a ship ... green lines? It is funny to this sea sick sailor anyway.
Thanks for using FixYa.com
Nov 02, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Acer Aspire 5100 Notebook Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
