Question about Brother Office Equipment & Supplies
Brother MFC 885 CW needing to replace Logic Board ... Please advise 'rough' quote to repair as I do not wish to go back to Harris Technology . Regards Dino 0405131062
  • 610 Answers
You would be better off buying a new machine- not worth the repair.
Posted on Nov 17, 2009
Brother MFC 6490 CW--have an error message "unable to print 6F" what does that mean and how do I fix it
This indicates one of 4 problems. They are in this order from easiest to most difficult.
1 Malfunction caused by overload (unplug the power cord and wait 5 seconds then plug back in.
Open and close the scanner cover.
2. ASF encoder sensor defective (Replace ASF motor assy)
3. ASF Motor defective (Replace ASF Motor assy.)
4. Main PCB Defective (Replace Main PCB)
If this is any problem other than 1 above you will need an authorized service center.
Good Luck
Mar 26, 2011 | Brother MFC-8440 All-In-One Laser Printer
MFC 6490 CW I installed new colour cartridges, cleaned heads but it wont print in colour???
Hi I'm sorry say your machine will need a new print head and they are not easy to fit my suggestion will be to contact brother by email and ask if they will suggest a repairer in your area
but I would look at replacing it with a canon or a hp
Mar 08, 2011 | Brother MFC 6490CW InkJet Printer
I had the Brother mfc 490 CW connected to a lan network and it was working OK. Just two days ago I unplugged the printer and moved it to another spot in the same room connected to the same lan. When I...
Hello!
"No Station ID" means that your printer is in the mode "Transferring faxes to another fax
machine"
Brother has a Solutions Center.
I add a link to this center, hope it will help you resolve this problem asap.
United States Brother Solutions Center
May 30, 2017 | Brother MFC 490cw Color Inkjet...
HOW DO I PRINT AN ENVELOPE ON A BROTHER MFC 6490 CW
the plastic indicater should slide back and forth to adjustr from paper to envelope
if you dont have the manual to figure this out , go to this link
http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
leave positive feedback for me please
Oct 16, 2010 | Brother MFC 6490CW InkJet Printer
I have a Brother MFC-885 that shows paper jam although all paper has been removed What do I do please?
Common problem. Open the back door and check the sensor flag and make sure it flips back and forth freely. Check the spring. Also check inside the drum cavity ares for same flags.
Dec 30, 2009 | Brother MFC-845CW multi-function...
Trouble shooting clean unable 50
Alright, i have to tell you, this is a really bad post. You gave me nothing for information. But from what information i can gather, it could be error number 50. on a brother DCP-145C. Heres the problem with brother printers. They are cheap to buy initially, but break and can't be fixed easily without being a "Certified brother technician".
Either way. I think you have to replace the logic board on the unit, possibly. Possibly check the connections and use sand paper and undo some connections sand the copper, and put them back in. Logic board will likely run you over a hundred, if you need to replace the fuser, thats over 100 again. Expensive repair. If it had been an HP printer, i could have explained it thoroughly, i'm sorry i can't be of more help.
Sep 20, 2009 | Brother Multi-Function Center MFC-240C...
Unable to clean 46 mfc 490 cw
Hello there muvera.
You are 100% correct. The number of ink purges reached the limit allowed by the printer.
Brother does this because there is a physical ink absorber box that absorbs all the excess ink the printer excretes during normal use. If you just reset the counter, ink will spill all over the inside of the printer, so I would strongly advise against just resetting the counter.
Since it appears like you have enough expertise to open up the printer yourself, you need to replace part number LS4699001. Good luck finding that part, however. As a Brother Authorized Technician/Service Center, I can't just sell you parts to repair it yourself as it is against our merchant agreement.
Your best bet would be to just take it to your local service center or send it to Brother directly.
If you can obtain the part, I will be more than happy to walk you through the reset procedure.
If this post helped you, please comment back and positively rate my solution.
Thanks.
-Phil Traversa
Aug 18, 2009 | Brother MultiFunction Center MFC-440CN...
Cant finish installing mfc 490 cw printer install on my computer
Sounds like you may ahve the 32 bit version of the driver. Try uninstalling all brother software, then reinstalling the 64bit version from:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003600/dlf003657.html?reg=us&c=us&lang=en&prod=mfc490cw_all&type2=1&os=84&flang=8&dlid=dlf003657
Jul 11, 2009 | Brother MultiFunction Center MFC-440CN...
78 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
