Question about Hotpoint VBXR1090D Top Load Washer
Hotpoint VBXR1090 Washer
My washer sometimes won't Aggitate, a couple nights ago, it quit.
I pulled off the front cover, felt the motor, it was pretty hot.
I replaced the stabilizer cords on each side yesterday. One was broken.
When I let it cool, it started working. Does the motor have a load relay on
it that when it gets hot, it stops ??
Sometimes it won't aggitate on a small load neither.
  • Whoop 55 Mar 03, 2008
    It's not that old, I replaced the Rubber Shock Straps, one was broke. Releved it and it's not had one problem.
  • 121 Answers
Sounds like your brushes need replaced or your motor would try the brushes first
Posted on Mar 03, 2008
Hotpoint washer won't spin or agitate and has black soot - is clutch out?
The motor coupling is attached to the shaft of the motor. The "soot" is probably the result of the coupling shredding prior to failing
Oct 09, 2012 | Hotpoint Washing Machines
Hotpoint drive belt
un plug appliance, remove lid and back plate, place belt on motor and carefully on drum pully, turn pully to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i tighten the drum weights on my hotpoint
Remove rear cover, and you will see the concrete weight at the bottom, sometimes the securing nuts work loose, or break off.
There is also a concete weight in the top of the washer as well,so check this as well
Feb 04, 2010 | Hotpoint Aquarius WD640 Front Load...
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Washer aggitate for 20 seconds then stops, starts
This could be your control switch. Remove the front cover at the top that has the dials on. Check main switch unit, it probably needs to be rebuilt, about $35 or installed new.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
Washer will not spin. Does everything else.
If it aggitates, then the tranny and motor coupling is ok. the drive assembly is bad. nintey perent of the no spin problems is motor coupling problem. But since yours will aggitate, then the coupling is fine.
Jul 12, 2009 | Whirlpool Inglis IP4400 Washer
Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
