Question about Cell Phones
I have the cect i9 ok and i went on this website and i tried to download some java games and im stuff but it wont work on my phone and then i cant download anything via usb help please
I have a i9phone from china and I dont have java.. I cant play any games without it.. I have no java applications or anything.. I need a step by step process how to fix this problem please
Probably you have a phone operating system without JAVA. It is possible because people can change I9/I9+++ operating system by another. One possible to download in net is without JAVA, so there are no chineese games and dialers. But in factory operating system JAVA works and there is JAVA icon. It gets .jar apps installation and some JAVA regulations. One way to return JAVA in phone is to change operating system using MTK tools and special cable (not that used to normal downloading to phone). It is difficult procedure not quite described in net. But... I9/I9+++ has slow , about 50MHz processor and only simple JAVA applications works well. Do not expect to GAMELOFT games work slightly. For instance java pdfviewer load one page about 2-5 minutes.
Aug 17, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do i delete the java games on my cect i9
Being that the game is on the cell phone memory not the external memory... be very cautions on deleting...go to the game it self and go to options (you can delete from cell) before starting
May 11, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Sciphone i9 java script and internet browser is in chinese?
You need to install an english browser!
Google for "opera mobile" and download it.
Oct 01, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I NEED HELP REPAIRING MY I9 SCREEN
There are basically two ways to do this. You can get online to the Java website via your WAP browser and enter in the code for the CECT installation ((wap.GetJar.com and then quick the download code 30827.) I usually download via USB though as this puts a copy onto my computer (in case it accidentally gets deleted) and it doesn?t cost any money or data to do this. For the Java installation, go to the get jar website. Make sure that you have the device set to CECT A100 (the CECT default.) Connect the phone to the computer via USB. Hit the mass storage icon on the phone. Click on the jar file that you want to download. Click save. Next, find the drive that your phone is listed under. (For me, this is K:/, but it may be something different in your case.) Click OK. Then, unhook the phone from the USB. Go into the document icon on the phone. Find the received file and then scroll down until you see the browser and click it. Then click ?install.? Now, you?ll go into Java icon. You?ll see the browser in the list of Java files. Then click launch. Opera should launch and you can start browsing. Most often, when something goes wrong here, it?s because the data, WAP or Java settings aren?t correct. You?ll need to go in and set them up depending upon your carrier. For example, if you use T Mobile, you?ll need to input the T Mobile WAP, port, and data settings. Typically, you set the data first, then the GPRS, the WAP, and the MMS. Finally, go into the JAVA settings and make sure that T Mobile (or AT&T, or which ever carrier that you are using) is reflected. There are many resources that will give you the Internet settings for almost every applicable carrier that you can think of. If for some reason you can?t get online, I?d check to make sure the phone isn?t set to the original Chinese or factory settings. To view video, close up photos, full specifications, and real time rock bottom pricing on the CECT i9 please check out http://i9clonephonereview.com/ If you need a USB cord for the i9 (or other accessories including internet, MMS, or WAP set up instructions, cases and skins, unlimited data sim cards, memory cards, batteries, etc,) please visit http://i9accessories.com
Jun 15, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Games not working
You will need Java games that work with the phones touch screen! Most of them do not.
Find some i9 games at http://chinamanuals.com
Mar 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Apps for cect 3G i9 touch phone and english java games
Ok you should be able to go into JAVA on you i9 phone and select OPTIONS and delete the chinese games. As for other apps, I have not been so successful in finding the ones that are like the apple phone but here is a site that has games for your phone www.getjar.com
You do have to select your phone but here is the link with the i9 already selected :
http://www.getjar.com/software/CECT/A1000
The games are ok but it dinda makes you feel like you just bought a portable Nintendo ES....
Feb 19, 2009 | Cell Phones
Please tell me exactly how to put java apps and movies on the i9
Ok, Its pretty simple to add java apps/games and movies to your i9. just
1) connect your phone to your pc via the usb.
2) go into your i9 phones memory card (the first of the two letters) i.e I = phone memory , H = memory card.. so go into the H drive.
3) Create a folder call 'JAVA' and simply drag your downloaded apps/games from your pc into your 'JAVA' folder on your memory card!
4) When you disconnect you phone, go to java in your phone menu then you can install the apps/games.
(step 3 only need to create 'java' folder once)
For movies
1) repeat step 1 and 2 above ^^
2) drag the movies from your pc into 'Movies' folder on memory card
3) disconnect phone from pc and you can now watch on your phone!
Note: i9 phone supports 3GP, AVI format only.
Jan 24, 2009 | Dual Electronics CECT P168 Cellular Phone
My i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
Jan 19, 2009 | Apple iPhone Smartphone
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
